Jk lights
Old 01-31-2015, 10:48 AM
zackjk's Avatar
Default Jk lights
I just bought a used 2007 Jeep Wrangler Sport. The person I bought it from had put some Westin off road lights. The problem is they said the lights won't turn on because they aren't wired correctly. She said I needed a switch. I know nothing about offroad lights and am very new to Jeeps. In the glovebox I found a switch but it wasn't connected to anything. It looks like they are wired into the Jeep but I have no idea where at inside. If someone could help I'd really appreciate it.
Name:	Jeep lights.jpg
ID:	594601   Click image for larger version
Name:	Jeep lights 1.jpg
ID:	594603   Click image for larger version
Name:	Jeep lights 2.jpg
Old 01-31-2015, 11:21 AM
Waldo_88's Avatar
Yikes, I hate dealing with electrical. Follow the wire from the back of the lights into the cab. Don't be afraid to pop of the panels in and around the dash, they are just plastic clips that snap right back on. You'll probably find a red wire leading to the battery, and a black or white wire leading to a ground. Theeeeen another couple of wires that need a switch tied to them. Good luck buddy, it's hard to say without being there.
Old 02-01-2015, 03:15 AM
14Sport's Avatar
This is how they should be wired using a relay. They may be negative switched or positive switched. Trace the wires and see what's missing.
Name:	SPST Relay (+switched).jpg
ID:	594698   Click image for larger version
Name:	SPST Relay (-switched).jpg
Old 02-01-2015, 11:07 AM
iox
iox's Avatar
If you're not comfortable configuring a relay to power your lights, you can also purchase a relay harness that's pre-wired at your local auto parts (they even sell some with a wireless switch, but those cost more). I'm sure a local stereo/alarm shop would also charge you a decently fair price to wire them up for you. Even the right buddy would probably do it for a single
Old 02-01-2015, 12:00 PM
14Sport's Avatar
Nope. Six beer minimum.
Old 02-01-2015, 12:05 PM
14Sport's Avatar
It's also possible they were wired without a relay. If that's the case, the schematic would be more like this.
Name:	No Relay Accessory Wiring.jpg
Old 02-02-2015, 08:12 AM
Ripa777's Avatar
If u plan on adding more lights u should look into getting a sPOD.
Quick Reply: Jk lights
