LED tail lights on a JK...anyone?
im pretty sure i remember reading somewhere that the jk has square openings or something. So im guessing in the above picture, they just drilled a circular hole in the armor where the square is to accommodate a round light
check out this thread if you are still interested in something like this.
https://www.jk-forum.com/forums/sponsoring-manufacturers-vendors-check-out-cyber-monday-specials-24/led-rear-corner-gaurds-24432/
David
David
It's hard to believe there not on the market yet for the JK considering they have been on the market for awhile now. You know the first ones to hit the market are gonna make a killin
I got LED bulbs at Auto Zone. Probably the same ones as no9, not quite as bright as stock and the light is not dispursed as well. Also the fast blink problem. They plug into the stock recepticle.
I would love LED tail lights on my JK. I found some OEMs for earlier years but not my JK. Here is what my Dad put on his new truck camper. I dont think these are the same model but they are brighter then H3LL. When you signal or break I'm pretty sure the person behind us looks like this ........
7-1/2 Red Led Stop/Tail/Turn surface mount
http://www.vehiclelight.com/861088.html
7-1/2 Red Led Stop/Tail/Turn & Back up Lamp surface mount
http://www.vehiclelight.com/8620.html
Root Site Link
http://www.vehiclelight.com/ledstli.html
-Edit-
I know there is a company that makes flat LED panels to go inside the tail light lens but I wasn't able to find them ......
Root Site Link
-Edit-
Last edited by Robar; 02-08-2008 at 06:35 PM. Reason: Please dont post direct non sponsor links.
they have alot of different sizes and styles and you can find a chart that tells you which bulbs you need. I think you can buy resistors also but I didn't get those yet. Hint though get the most Leds per bulb expecially for the reverse lights
Last edited by Robar; 02-08-2008 at 04:56 PM. Reason: Please dont post direct non sponsor links.
