Light bar switch mounting
I recently purchased a 20 inch led light bar to mount on my 2015 unlimited rubicon. I need suggestions where to mount the switch. In the dash there appears to be extra slots next to the heated seat switch or over next to the differential lock switch. Is this actual ya usable area or do I need to cut a hole in the dash? Is it possible to put in the A-pillar as well? Don't mean to ramble but I'm an idiot when it comes to this stuff
Behind the factory switches there is a circuit board so using the blanks wouldn't be easy. It would involve sanding down the blanks and installing a micro-switch with epoxy. There is a video on youtube. He said he was going to post another video of it actually hooked up but he never did, so I'm guessing it isn't as easy, or maybe dependable, as he thought.
https://www.youtube.com/watch?v=9QrDxvd6uj4"]https://www.youtube.com/watch?v=9QrDxvd6uj4
It's actually extremely easy (I just did the same thing) You remove the visor, then the christmas tree screw out of the 2nd hole down on the a-pillar. Pull that trim piece off and the middle a-pillar is just clips. The side of the dash pops right off and running the wires is a breeze
