Morimoto D2S HID Projector Retrofit
#21
Great write up on the install!
I did this to my black JK and am really digging the look!
Attachment 336884
Attachment 336885
Attachment 336884
Attachment 336885
#23
AWESOME job!
I technically just done my third retrofit recently. What's better than one set of Morimoto'? TWO of them! I re-done my headlamps since I had a slight learning curve on the first set from a couple years ago. The mini H1's I removed my first go was a little too crappy to sell, but to nice to throw away, so I ended up retrofitting them into the fog lamps. It is certainly tight in there, but they do fit, quite nicely I must add.
Now I essentially have four sets of lows or highs, the light output is phenominal! The solenoids in the fogs are tied in with the headlamps, so they'll stay on with the highs, I had to put them on an independent switch. A PVC 3" to 1.5" reducer works perfectly.
I used the JB Weld putty on all the retrofits so far with no ill effects.
Here's a completed fog.
#24
I like it.
AWESOME job!
Attachment 341015
Attachment 341015
#25
@ominx
... Great write up. I have alot of experience with these retrofits, and just decided on the same brand myself. The fact that I got them on the phone made the diffrence... Much different than using ALIBABBA to do custom hacks for 3kGT's. Great warranty too.
I will post mine when i finish them, doing the ROBO-MOD.
#26
hey just a question to any of you who bought the kit.... for the wiring harness were you guys ok with the H13/9008 or did you have to buy the mopar specific harness?
#30
