Mygig Mic Kit - 9.599 Disc
Results 1 to 8 of 8
  1. #1
    Join Date
    Nov 2007
    Location
    Alberta, Canada
    Posts
    8
    Default Mygig Mic Kit - 9.599 Disc
    Hi, I received an update disc from HB in the mail a couple months along with a "special" disc for the JK Uconnect. It says "Wrangler JK Special Software for VR/HFM Microphone Based off 9.556"
    I installed the mic the connector, checked everything, Installed the update and pressing the buttons still brings the "not equipped" alert up. Has anyone else had this little kit from him, with any success? I am going to wait for the new update anyways to see if it resolves anything, but I was wondering if anyone had any ideas. Are there any more steps then the install mic, update software that need to be taken? I cycled the power a few times.
    Thanks guys, any help would be greatly appreciated
    -- 2008 -- Black -- Sahara --
  2. #2
    JK Enthusiast CyBrChLd's Avatar
    Join Date
    Jun 2007
    Location
    Ft Lauderdale, fl
    Posts
    249
    not sure if that version enabled the microphone but you can Download the latest software which is 9.713 which has the mic support or just contact harman becker and theyll send you a cd.
    2007 Sahara Unlimited
    3" Skyjacker coil lift
    Skyjacker Steering Stabilizer
    Skyjacker Nitro Shocks
    Pro Comp 8089 17" 35' Micky Thompson MTZ tires
    Air Raid CAI
    Hella500FF w/ KC brackets
    MidLand 75-822 CB
    3' firestick Antenna
    Performance Accesories 1" Body Lift
  3. #3
    Join Date
    Nov 2007
    Location
    Alberta, Canada
    Posts
    8
    yea I contacted him already and I'm still waitin for the new cd. I was just wondering because he told me this disc was supposed to enable it too. Do you know if the uconnect will work without the mic plugged in even so I can try to troubleshoot a bit more? Thanks
  4. #4
    JK Freak artpics's Avatar
    Join Date
    Mar 2008
    Location
    Calabasas - CA & London
    Posts
    854
    yes the uconnect VR will work without the mic plugged in,
    1. have you enabled VR
    2. i had to install my upgrade twice before it worked.
    put disc in let it install wait for the reboot then when it says do you want to install again DO IT, this worked for me.
    Jeep Wrangler Rubicon 2 Door 2008
    |||||| Silver
    Terraflex
  5. #5
    Join Date
    Nov 2007
    Location
    Alberta, Canada
    Posts
    8
    oh ill try that thanks! I did install it twice, but not again right after the first one installed, hope it works, then I can wait for the new disc in the mail instead of risking a bad burn doing it myself.
  6. #6
    Join Date
    Nov 2007
    Location
    Alberta, Canada
    Posts
    8
    nope, didnt work. thats a total of 4 times installing, i might burn the new 9.713 and give that a go. Has anyone had any problems with verbatim or maxell cd-pro discs burning at the slowest speed with these files? thanks
  7. #7
    JK Newbie BigKahuna's Avatar
    Join Date
    Dec 2007
    Location
    Pt. Pleasant, NJ
    Posts
    85
    Copied from another form
    Q: How do I access the MyGIG engineering menu?
    A: You can access the Engineering Menu of the MyGIG by pressing the 3 Hard Keys: SEEK UP - SEEK DOWN - MENU all at the same time. Which will allow you to test your hard drive, restore the system to factory defaults, reinstall corrupt software, Screw up your MyGIG permanently, etc.. Please be VERY careful when using this menu.
    http://mofv.com/mygig/
    When you are in the engineering mode scroll the pages till you find the Uconnect tab. It should say disabled press to enable and your done
    08 Silver 4dr Rubicon
    AEV , Warn, IPF, ARB, OME, Superlift
    More on the way
  8. #8
    JK Enthusiast Jumpnt's Avatar
    Join Date
    May 2008
    Location
    Escondido, CA.
    Posts
    125
    Thanks BigKahuna! That was exactly the issue I was having. My UConnect finally works!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
