New MyGIG Software Update RER-REW-REP v2.403
New MyGIG Software Update RER-REW-REP v2.404
The official MyGig update RER 2.404 available for download. I have verified it burns fine and with Nero Media Suite 11 or Express Burn Disc Burning Software by NCH. You can burn this to a DVD or a CD! (Please do not use the standard burning software that came with your operating system. Very rarely will you get a successful burn.)
I have installed and verified operation with the Lockpick installed.
If your HDD has failed and you need a new HDD or you want to create a new HDD by an image I highly recommend this site for your MyGig needs... http://mygig-disk.com
1. The .iso files are here ----->http://mygig-disk.com/mygig-updates/...-REW.2.404.iso
http://mygig-disk.com/mygig-updates/...-REW.9.807.iso
http://mygig-disk.com/mygig-updates/RER-REW.9.713.iso
2. Or you can receive a free disc from Chrysler here: (Takes 4 to 8 weeks to receive)
https://qna.extra.chrysler.com/rhb/r...dateRequest.do
Once the disc is burned.......
Do not attempt to install WITHOUT THE MOTOR RUNNING! If the MyGig looses power at anytime during the install you can forget about the MyGig ever working again!
It is VERY IMPORTANT to read the following instructions before you attempt to install. Failure to read could turn your pretty MyGig into a expensive brick mounted in your dash!
What ever you do do NOT remove the disc till the MyGig asks you to install the software a second time! This is the equivalent of the "Your installation is complete" window. Then you simply click "NO" then you can eject the disc.
MyGig versions in the order of release from newest to oldest
2.404
2.403
2.402
2.401
2.302
2.107
2.067
2.045
2.043
2.042
1.295
1.220
9.807
9.715
9.713
9.651
Here a list of all the fixes...
2.404 RER\REW No info found on the update changes.
2.403 RER/REW
TA (Traffic Announcements) bug fix...and uconnect phone list update
2.402 RER/REW released July 2010
I-Phone Bluetooth compatibility fix (You must be running Apple version 4.2.1 or newer on your device as well... )
2.401 RER/REW/REP:
Intermittent no sound from audio system when using remote start
Radio lock up when using U-Connect
Repeated "acquiring signal" message when in satellite radio mode
2.302 RER/REW released July 2010
Updated all logo graphics and use VEH_BRAND and special package for MY11 and
beyond
2.107 RER/REW released May 2010
Bug fix for Genre being reported as numerical value
Bug fix for flashes in the cluster after a HDD next track operation
Bug fix for GPS time lockup
Added support for new vehicle message matrix 911
Fully implement audio EQ 11.0
2.043/2.045 RER/REW/REP released October 2009
Added minimize button to hide/show all buttons on the map
Implemented PDO release for Nav OPTIONS, both in motion and in static
Change of all sub screens after HDD AVAILABLE CATERGORIES to read “EXIT”
instead of “CANCEL”
Added Pause/Play button to HDD and Disc per PDO Release
Diesel Gasoline POI category
Pop up to notify user that X tracks were successfully copied out of Y tracks
POI redesign
New Startup logo and associated changes for “Sterling” vehicle type (DA).
Added support for Fuel Saver Mode in the HS HEV (new signal
FUEL_SA_MD_ACT in CAN VMM820b). Continue to use CYL_DEACT for LS.
Several bug fixes for POI listing – alphabetical ordering, favorites and nearby POI
searches
Bug fix for phone call VR barge in failure
Bug fix for incorrect volume after call
Bug fix for no clock option for +9.5 and +10.5 time zones
Bug fix for blue screen while scrolling in construction area
Fix for navigation volume during a phone call
Fix for disc lock up when trying to add picture from disc
Bug fix for audio blip when seeking in FM mode
Fix for Nav Main Menu missing SK
Bug fix for blue squares displayed on map
Bug fix for GPS information not populating
1.220 RER/REW/REP released January 2009
Several Bluetooth bug fixes for Blackberry 8700, V3m RAZR and LG VX8550.
iPod charging bug fix that does not require iPod to disconnect.
Voice Recognition of “HOME” was missing and fixed
Eject disc during power off bug fix
Navigation Data Base for MY07 radio updates with RS6 or earlier bug fix
Several bug fixes after Nav Data Base update, touch screen lock up & POI by City
Several UConnect bug fixes – Radio does not exit UConnect after call transfer, no
ring on incoming phone call, Phonebook list is empty, HMI frozen and could not
access UConnect.
Bug fix for Speech Dialog System lock-up.
Several Navigation/Map issues – Trail not showing on map, adding stop over while
in motion, reset caused by detour and avoid turn.
Bug fix for MEMO record
Fixed Dealer button on Emergency Screen
Speed and Flow information incorrect
Bug fix on radio reset during copy of large mp3 file from disc.
Black map after software update fixed
9.807 RER/REW/REP Software update disc (same as 1.055 software in Model Year 2009 radios)
New UConnect Functionality – support of Phone Book Download from compatible
Bluetooth Hands Free Phones. A paired phone will automatically download phone
numbers to the MyGIG address book. Radio provides Voice Recognition to all names
in this download. User can manually store individual names to the permanent address
book.
Added more Bluetooth Compatible phones (many new phones including Motorola Q)
Human Machine Interface (HMI) improvements
Added Alpha jump to HDD lists (select first letter in a list instead of
scrolling through list)
Moved JB (Juke Box) tab to FAVORITES under HDD
New progress icon for downloading music
Changed some POI icons on the map (removed yellow background)
Added phone book download status icon under UConnect screen.
Improved reliability of downloading Maps, Gracenote and application updates
Major Bug fixes
Fixed all audio mutes (missing audio) on Start Up.
Increased the number of Sirius Traffic messages and speed/flow
Note, iPod support is only available today through Model Year 2009 radios via a
serial port out the back of the radio. It is not currently an upgrade for Model Year
2007 and 2008 radios.
9.713 MY08V2.2 RER/REW/REP released March 2008 mailed to all dealers and users
Enable Wrangler microphone for UConnect and Voice Recognition
HDD firmware update to prevent Master Cylinder HDD corruption
Able to play imported compressed music from same album in order of the track
number
Navigation data base improved update software
SAT preset to new defaults
No change to Navigation or Gracenote data base
Note – Mopar Part Number 1-CDL1H111
9.665 MY08V2.1 RER/REW/REP released January 2008 only in for new production units
Graphics Accelerator for faster 3D map
Overlay Sirius speed and flow on Map in three colors, RED, YELLOW & GREEN
Update of UConnect bluetooth drivers for Verizon phones (i.e. Motorola V3)
Faster POI lookup
Improved Software update process using CRC error check
9.561 MY08V2.0 RER/REW/REP released October 2007
5 second timer on Accept Screen (aka Nag Screen)
iPhone Uconnect support added
Saves the Nav Prompt volume to 0 over an IGN cycle
Fixes loss of SAT presets
9.556 MY08V1 RER/REW/REP (North America, Europe, Middle East, South Africa, Australia)
released July 2007
Bug fix radios stuck in Spanish or French (Wrangler)
Bug fix radios stuck in Demo mode
9.041 MY07 RER (North America) launched in March 2007
Launched on Nitro, Wrangler and Sebring (Avenger)
Navigation Data Base 1Q06 (March 2006)
Gracenote August 2006
8.044 MY07 REW (Europe) launched in December 2006
UConnect & Voice Recognition Disabled
2.404
2.403
2.402
2.401
2.302
2.107
2.067
2.045
2.043
2.042
1.295
1.220
9.807
9.715
9.713
9.651
2.403 RER/REW
2.401 RER/REW/REP:
beyond
instead of “CANCEL”
POI redesign
searches
access UConnect.
book.
Major Bug fixes
number
Faster POI lookup
released July 2007
I don't have a MAC but these are the instructions I received from a fellow member of JK forum.
For MAC's only!
Make sure to rename the disk to whatever the update is!!
when I downloaded the files whpony96 provided.. one of them was missing the version number. it needs to be like this for the System update =
RER_2.403
and this for the Gracenote update=
Gracenote
so again to recap
To update the navigation operating system you will need to download this file
http://www.mydrive.ch/
username: mygig@soxag
password: gasolio
go to software updates - gracenotes update and\or RER 2.403 Update
1- Unzip it
2- you will see a folder. make sure that the folder title is RER_2.403 and that there are 2 files and 1 folder inside that "RER_2.403" folder.
3- Insert a CD
4- (Mac users only!) right click the RER_2.403 folder
5- you will see Burn "RER_2.403" to a disk. click it
6- double check the CD name. again make sure it's RER_2.403 or it will not run on your nav.
7- select the slowest speed to burn.
8- wait for it to finish.
9- start your Jeep and wait for the Mygig to load.
10- insert CD
11- wait for the screen to load. then select update.
12- DO NOT TOUCH ANYTHING! DO NOT TURN OFF YOUR JEEP! let it install and then once it's done it will restart.
13- Mygig will bring you back to that same screen you were prompt in step 11. at that point you can eject the CD and shut off your Jeep
same case with the Gracenotes
if you are updating your maps (you have to pay $150 for this)
it will take an hour and also keep the Jeep running or attach a battery charger.
For MAC's only!
RER_2.403
Gracenote
so again to recap
password: gasolio
1- Unzip it
3- Insert a CD
10- insert CD
HDD Will not work
Thank you for your update help. I was able to burn the 3 updates and they loaded into the mygig with no problems. I am now running 4.203. Unfortunately, I am still having problems with loading music into the HDD. I tried to delete the HDD to clear it and start over, but the message "Deleting Please Wait" comes up and stays there for far too long. The HDD shows no songs or playlists, but if you check the HDD status it shows 1.5 GB used. When I put a CD into the CD slot, it plays it but does not have a soft key for Copy Disc; it I go to My Files, Import from CD, nothing happens. Do you have any suggestions? This HDD feature was working at the old version (5.671) before I updated.
Thanks for your insight.
1.Does you Mygig say "RER" under the USB port on the right hand side?
2. When installing the updates did you just install the updates one right after the other without cycling the CanBus on the Jeep? (This means that once you finished each install and you see the screen that says "Would you like to update from 2.403 to 2.403" and then eject the CD, did you shut the JK off for 10 minutes get out and then get back in and start the next install.) IF you did not reset the CanBus between each install you will need to start over with the installs. This is VERY IMPORTANT that you reset the CanBus after each update.
OK as far as I know there is no such version as 5.671. That's OK since there is no way to find out now what version you originally had on your MyGig. So I have a couple questions for you.
OK you had the original software on the MyGig from when it was first released. Upon updating it if you did have A LOT of music on the harddrive (HDD) it can take hours for the OS to update all the music on the HDD to the new format. (The older version of OS there was a bug in the OS that caused the HDD to actually corrupt itself and turn the MyGig into a brick) Once you installed the update the OS started rewriting all the Data on the HDD to the new format. This can take hours if there is a lot of songs on the HDD. This is why it said there was songs taking up space on the HDD but it did not list them when you went into the playlist.
How long have you let the MyGig run since you have updated it?
It's all there!!! I had no idea that it would take that long to recognize the music. Thank you very much for your help. All is well in my Jeep world!
