New MyGIG Software Update RER-REW-REP v2.403
Old 04-22-2012, 06:10 PM
  #21
JK08MCS's Avatar
Default Not sure
Not sure if this would help me out. The MyGIG don't play any of my DVD's or CD's sense I've tried to play a bootleg CD my brother in law gave me for my wife to listen to on the trip to Canada a couple years back. You think it would be unwise to try?
PS: Everything else works great and don't want to lose what I have left
Old 05-03-2012, 07:18 PM
  #22
Jollydodger's Avatar
How do you suppose you are going to update the firmware with a cd if it isn't reading cds? Sounds like the eye is not working.
Old 05-04-2012, 10:29 AM
  #23
whpony96's Avatar
OK you can tackle this 2 ways one you can open the MyGig and manually clean out the unit or you can insert a cd rom cleaning disk. (The cd rom cleaning disk has soft brushes attached to it and it will gently clean off the laser lens...)
Old 05-06-2012, 09:34 AM
  #24
JK08MCS's Avatar
Seems like I'm dropping the ball on this, sorry. Thank you Jollydodger and whpony96 I'll try this today and get back to you on the outcome. Told my wife no more home burned CD this morning and "here" I am wanting to upgrade with a CD i'll burn.
Old 05-08-2012, 08:47 AM
  #25
sdr0303's Avatar
The link to the RAW files is not working. Anyone know where else these can be downloaded?
Old 05-08-2012, 09:00 AM
  #26
whpony96's Avatar
Fixed!
You can now download the raw files or a .iso
Old 05-08-2012, 09:15 AM
  #27
sdr0303's Avatar
Great thanks!
Old 05-10-2012, 02:57 AM
  #28
Russ's Avatar
Default MYGIG, Uconnect, Blackberry Curve 9360
2012 Jeep Wrangler Unlimited Rubicon
Media Center RHB 430N CD/DVD/MP3/HDD/NAV
Uconnect Voice Command w/Bluetooth
Info from unit.
Application 33.01.19
Application CPU 122611
SIRIUS 1A.00.1E.14
Gracenotes D9F
Hardware
SN T00AM0822T0633
System 0207bbbb
No problem pairing the Blackberry Curve 9360 running OS7. However, phone book will not download and sync. Also, text feature does not work. Blackberry issue? Uconnect issue? Not sure where to go to request help from the manufacturers of these devices..
Anyone else have similar issues? What did you do to fix it?
Thanks,
Russ
Old 05-10-2012, 05:59 AM
  #29
whpony96's Avatar
Info from unit.
SIRIUS 1A.00.1E.14
Gracenotes D9F
Hardware
SN T00AM0822T0633
System 0207bbbb
Thanks,
Russ
What 3 letters are located in the lower right hand corner of the frame around the mygig face of the radio? RHR, RHB,..ect.....
Old 05-10-2012, 08:02 AM
  #30
redleg13fa's Avatar
Well had the problem with my bluetooth dropping on and off as well as not being able to connect mp3 to the usb port in center console. Dealership ran test and and it failed. Had the software upgrade to. So now dealership is ordering new radio replacement. (Mygig430) is the radio. 2011 j/k ru. Problem solved.
Quick Reply: New MyGIG Software Update RER-REW-REP v2.403
