Quadratec Sound System: Will I Have To Buy Anything Separate?
No experience with that set up but the plug and play harness they are talking about sounds bogus to me since a 1200 watt amp will require 4 gauge wire, a inline fuse, 4 gauge ground wire no longer than 18", and a remote wire to a switched 12v source
The power wire and ground wire could possibly be a 8 gauge if it's not a true 1200 watts
Sponsoring Vendor
Hey there!
The kit includes everything you need (including all of the wiring) to install the system in your JK as long as you still have the factory radio. It is also very important when ordering the kit to make sure you select the kit with or without the factory subwoofer (Depending on what you have). There are two different systems. If you have any other questions please feel free to call our supplier. His name is Bob, owner of a small mom and pop shop, Chadds Ford Electronics, here in PA. He is a JK owner himself. His number is: 610-358-1886.
Thanks and have a great day!
-Rick
-Rick
