Replacing the Factory Subwoofer wiring question
i bought a Kicker Compvt 8 to replace the infinity subwoofer as it sounded blown to me my question is the factory sub had two plugs, each with 2 wires going to them. which are positive and negative? the Kicker has just a Red and Black input so thats easy enuff, but what wires do connect? thx in advance for the help guys and gals
Factory sub is a dual 2 ohm sub, you will need to replace it with a dual 2 ohm sub. You should know that if you are using the factory "Alpine" amp, it will be severely under powered. I have read elsewhere that each channel of the sub output is approx 25 watts RMS, 50w peak.
bummer
well after seeing the 2ohm answer, i looked at the box of the speaker and see its a 4ohm speaker. do i need to take the speaker back or is there another idea?
Trade it in for a dual 2 ohm (meaning it will have two sets of speaker terminals each measured 2 ohms). Even then, I'd suggest running an aftermarket amp. Minimum I'd give a sub is 300 watts RMS, even with that you won't hear it from the back with the top off while driving.
