Rugged Ridge Switch Wiring Diagram
I was surprised that the Rugged Ridge A-Pillar switch pod didn't come with a wiring diagram for the switches. I found this online and thought it might be useful to others.
http://www.omix-ada.com/instructions/17235.01.pdf
Still trying to get mine wired correctly with my KC Driving lights. I put the the tan ground to the brass colored post, the green wire on the post next to it and the white on the last post. Still cant get them to work. Is it possible I blew something or broke somethign by wiring incorrectly.
Just installed some rock lights and used these switches. After a few hours and many unsavory words I finally got it hooked up. Copper=ground, middle=attach accessory, last=12v source. I used one of the positive wires from the cigarette lighter to run power. If you use a direct battery hook-up the LED light will stay lit with the ignition off causing battery drain.
If you swap the two non-grounds the switch light will only light up then the switch is on with direct battery hookup. I had the same problem initially.
