Seat wiring HELP!!!
Seat wiring HELP!!!
I have a 2007 JKU Sahara. I recently bought a complete interior from a 2015 JKU Sahara. A deal I couldn't resist.
It has turned into a nightmare of chimes and lights on the dash.
I discovered the connectors are different under the seats. I managed to splice the drivers side wiring and that took care of the seatbelt chime and light. The passenger side is a bastard to figure out. My jeep has the C307 connector with 4 wires. From what I could find online they are for ground, CAN BUS (+), CAN BUS(-), and fused B (+). No idea what that means, but the plug on the seats is an 8 way C326 connector and I can't find any detail on what wires to splice to get rid of the airbag light on my dash.
Can someone help on this before I sledge hammer the whole vehicle in a fit of frustration. It's a seat for Christ sake! How complicated are they going to make these things??!
I don't want to take this thing though water now I know how much electronic interconnect there is.
Cheers
oatz
Cheers
oatz
Not much help but this site sells oem connectors and shows 3 different passenger side connections for airbags...
Mopar Connection Repair Kit
Just choose 2015 JK and you will see them with wire colors when you click on them.
Thanks 14 sport, I actually got the connector data from that site already, but there isn't any detail in the '15 model connectors, only the sensors. The closest data was for a '13 model year which has a similar connector, although the wiring may have different colors. The issue is that I can't see any labeling on the newer models relating to CANBUS wiring. I went to the dealer, and I was not exactly shocked to discover they were no help at all.
That's the C1 connector. If you look at the passenger seat track pic I posted earlier you can see where it is. That's the pinout for no side air bags. The C2 pinout and the side air bag pinout are also on that site I posted earlier. Do the 2015 JK option and then scroll down to Module-Occupant Restraint Controller c2.
