Smittybilt 55watt fog lights
i would assume you will require a relay and a power source. far to high of wattage to run through factory wires. factory wire will serve only as a means to switch relay on and off. so basically same as wiring any other light.
My friend ran a relay for me. Lights are working but the relay is making a slight clicking noise. Would it be okay to run the power source from the battery? If I turn my fog lights on with the car off, there is no noise. When I turn my car on with the lights on the clicking noise appears.
Thanks 👍👍
Thanks 👍👍
My friend ran a relay for me. Lights are working but the relay is making a slight clicking noise. Would it be okay to run the power source from the battery? If I turn my fog lights on with the car off, there is no noise. When I turn my car on with the lights on the clicking noise appears. Thanks ddc4dddc4d
