Smittybily xrc Front bumper install no fog lights ???
I'm going to be installing a smittybily xrc front bumper. I don't believe it has room for the factory fog lights. I did order some PIAA 510's can I use the the factory fog lights wiring for the PIAA's or does this bumper allow for the factory lights to be installed? Anyone know about the install for this bumper? If possible I'd love to run the factories AND the PIAA's??
anyone know more about the install on this bumper such as the air bag sensors etc
thanks
thanks
thanks
thanks
The install of this bumper is fairly easy. I did it without any help.
Just use the exisiting wiring from the factory fogs?
I've done it as have several of the people I wheel with. Simple, almost plug and play...just take the existing wiring and tap into the wire leads off of the new lights and turn them on/off the way you would have with your factory fogs.
Super simple, and no, it does not take factory lights. I had tried 'fabricating' a 3" PVC cap thinking that it might fit in one of the holes underneath but was terribly unsuccessful.
I bought a set of Hella 700FF's and modified them to fit my HID bulbs from the stock lights in there.
