Starting issues 2008 jk wrangler,
Old 07-14-2014, 05:25 PM
ridgerunner17's Avatar
Default Starting issues 2008 jk wrangler,
Just clicks when starting , starter , battery. , starter wire connector, start run relay. @ starter solenoid relay have been replaced , still happens , need help
Old 07-14-2014, 05:35 PM
Serg5000's Avatar
Have you tried pushing forward on the shifter while attempting to start it? Or putting it in neutral then trying to start it?
Old 07-16-2014, 07:34 AM
no , i havent ,
Old 07-16-2014, 08:20 PM
Mr.Smith's Avatar
I have had a similar issue. I researched this for a while and found that for me it was a sensor associated in the transmission. Like what was mentioned above the trick worked every time.
Old 07-20-2014, 05:42 PM
What sensor was it ? I want to try it
Old 07-20-2014, 07:14 PM
PS83CP's Avatar
I had this happen last week. Mine turned out to be a short in the battery that completely fried it, so it wouldn't even jump start. BUT while researching I found that some of the keys with chips in em have had issues and needed to be reprogrammed/software update
Quick Reply: Starting issues 2008 jk wrangler,
