Stereo Install HELP!
I have a 2010 Wrangler Sahara with a factory sub.
I just got a Boss 9362BI Double-Din with a PAC C2R-CHY4 connector.
My main issue is I have TWO wire harnesses that went into the back of the factory HU. The large one fits into the PAC, but I have no idea where the smaller one goes... Do I have to pull the wires out and splice them somewhere? Does anyone know exactly what these wires are or where I would put them?
I have not installed a car stereo in over 20 years and they sure have changed!
Any info will be appreciated, the dash is apart as we speak!
If i remember correctly, the smaller one isn't used. That's the steering wheel controls I think. I have the rp4-ch11 and the wiring harness that came with my aftermarket stereo wired to the pac, then the pac plugs into the cars stereo harness. That small one wasn't used. Just tuck it away somewhere
Thanks for your help.... I am hoping its smooth sailing from here!!
No problem! I got my headunit from crutchfield and came with an antenna adapter.
It is a tight fit to get everything tucked in behind the new stereo. The sub-dash may need trimmed. Its a metal bracket that kept the old stereo in place behind everything. You'll see what I mean. Unless 2010s don't have it.
Make sure everything works before you put the dash back together.
Good luck!
Good luck!
