Stereo upgrade
I'm using the kenwood bluetooth. The reason is that I want to use pandora with my phone. It won't let you use bluetooth connected to the u connect and send audio to the kenwood side for the integrated pandora control.
It comes out with 2 screws. The two in the picture holding the cut bracket are the only ones holding it in. they are the same 7mm hex head screws found on the rest of the dash. I did the cutting on the bench and ground some of the sharp edges from cutting.
Dave
Dave
Using the Kenwood bluetooth does not render the phone and voice buttons useless with the maestro system. They can be programmed via computer to do anything. So, they could activate the phone via the kenwood. Or do something else.
Dave
Dave
