Sub box plans
I have a 10" subwoofer mounted in the area between the roll bar and back seat of my JKU. I'm not sure if there is much of a difference between the 2 and 4 door or what you are going to be mounting it in. After working on it trying different mounts for about 6 months I found something that is pretty sturdy, doesn't look completely out of place (at least to me), and if somebody really wanted to steal it if I had my top down then I'm at the point of saying their win because it took me an hour and a half to get it in and completely tightened down the way I wanted it. When I get a chance to take some pictures of it I will try to post them. Altogether I have about $50 into the box and mount but more than I would like to count in hours of building and installation.
Attachment 612664
This is the inside shot, sub is a Polk db1040 DVC running off of a sound stream Picasso nano 5 channel amp with Polk db651 and db6501 speakers in the stock locations with my stock HU
That's nice. What's the box volume? What's the box depth? How do you like it? This is about the same setup I'm going to have. I'm running away from the Polk db1040 DVC because of the pole vent and I don't want the box to stick out into the cargo area (depth of 6 inches.
Any chance you can take some pics pointing up into the footwell to show how the mounting plate for the amp is attached. I'm ready to do the audio in dash thing this summer, and have resigned myself to just winging it when the time comes, with some brackets, cable ties, mdf and other options to hand, and just making it all work somehow. If you could take and post these you'd be helping me a great deal. Thank you.
Another Suggestion for you (If you haven't gotten too far along). Build the sub enclosure in the factory location. I was able to glass an enclosure in the factory location that didn't take up any more space and expanded the internal volume to .55 cu ft. It didn't stick up over the top of the tub so it wasn't hanging out there to be stolen, I could open the storage door below and looked somewhat factory. This was my first prototype Sub that I built the weekend I got my Jeep. Great with the hard top on, ok with the soft top, but dropped off considerably with no top. I eventually sold it and kept moving my woofers forward so I could get bass with the top off. This one has a 10" Rockford Fosgate shallow.
A bit off topic but I'm also looking for a sub solution and, based upon what you could reasonably expect from a Jeep, can't decide if a custom underseat design would be worth it over a compact all-in unit. The time and money to make something, with the extra parts and pieces to tie together, box, amp, cabling, woofer, is it going to be that much better, again considering this is a Jeep? Pricing out a reasonable woofer, amp and cables, add about $40 for a custom box, I figured this would run a minimum of $250 to $300.
If I am only looking to round out the music, across the whole range of classical to house, would a compact solution do the trick? Along with Kicker, Kenwood and many others, I found this:
http://www.cerwinvegamobile.com/all-...28-vpas10.html
which puts a 10in sub from a decent brand into the mix. Any user feedback from this and other all-in underseat offerings?
Sorry for hijacking, just wanted to throw in another perspective while soliciting some feedback on the options possible.
A bit off topic but I'm also looking for a sub solution and, based upon what you could reasonably expect from a Jeep, can't decide if a custom underseat design would be worth it over a compact all-in unit. The time and money to make something, with the extra parts and pieces to tie together, box, amp, cabling, woofer, is it going to be that much better, again considering this is a Jeep? Pricing out a reasonable woofer, amp and cables, add about $40 for a custom box, I figured this would run a minimum of $250 to $300. If I am only looking to round out the music, across the whole range of classical to house, would a compact solution do the trick? Along with Kicker, Kenwood and many others, I found this: http://www.cerwinvegamobile.com/all-...28-vpas10.html which puts a 10in sub from a decent brand into the mix. Any user feedback from this and other all-in underseat offerings? Sorry for hijacking, just wanted to throw in another perspective while soliciting some feedback on the options possible.
