Switch-Pros SEMA Award Winning SP8100 Switch Panel Power System
Former Vendor
[h=2]Switch-Pros SEMA Award Winning SP8100 Switch Panel Power System[/h]
Awarded Best New Interior Accessory Product at the 2014 SEMA Show, the Switch-Pros SP8100 is unlike any other product in the marketplace! Here are just a few key features:
Check out this video for a complete demonstration of how the system works, and call us at 949-581-2991 with questions. To order, call or visit www.switch-pros.com.
https://www.youtube.com/watch?v=tXA1eVxxlRM
- 100 amp, all solid state, completely waterproof power module (NO RELAY OR FUSE BOX)
- Bluetooth interface built in (no additional charge; no additional module to install)
- 7 switches rated at 18 amps, 1 switch rated at 30 amps
- User adjustable nighttime backlighting
- Any or all switches can be programmed as Ignition or Battery Input
- Switches can be On/Off or Momentary, and can be programmed with memory function
- Lighting accessories can be programmed to have a Flash or Strobe secondary function
- A Master Switch can be programmed
- User selectable switch legends (sheet of 50 included)
- Built in over-current and over -temperature protection
- Made in USA
I installed this unit yesterday and I'm so pleased with the results. I was able to remove a bunch of wires and consolidate my spider web of wires. The install is clean and the instructions were thorough.
The pic above is how the unit looks installed. It took me about 3 hours to complete a clean install. I will be adding more legends to the panel this weekend. I installed it a bit differently than in the instructions, but I guess this is all up to you.
Former Vendor
