Switches for extra lighting
Old 07-19-2014, 06:03 PM
any4xx's Avatar
Are auxiliary switches available for the stock lower switch pod? My Jeep doesn't have heated seats and it would be nice to be able to use those two capped-off spots if I end up adding accessories.
Old 07-19-2014, 09:34 PM
orangedude71's Avatar
I'm dabbling with setting up switches that are activated by an iPhone using a headless raspberry Pi and wifi. The hardware to put it together is cheap, but the programming piece is gonna take some learning still. If I ever manage to get it breadboarded up, I'll start posting for real. The great part about this would be no physical switches in the car.
Old 07-20-2014, 12:54 AM
Mark Doiron's Avatar
I don't believe so. However, years ago someone did take that out and rebuild it. There is a circuit board back there that makes a simple plug and play impossible. There's no room to just install a switch from wherever.
Old 07-20-2014, 02:39 AM
darkknight1999's Avatar
I made my own secondary fuse relay block as well as a molded switch panel.
ID:	566413   Click image for larger version
ID:	566414   Click image for larger version
ID:	566415   Click image for larger version
ID:	566416   Click image for larger version
Old 07-20-2014, 03:14 AM
oooh. Your molded switch panel gave me a good idea. You have a write up on that somewhere?
Old 07-20-2014, 04:08 AM
No not yet... but I'm writing one, its just not done. I might get it finished up today if I have time.
Old 07-20-2014, 07:26 AM
JackDANJK22's Avatar
Damn ........ Nice work man !
Old 07-23-2014, 07:08 AM
groth797's Avatar
If you figure this out definitely post it on here! That would be awesome and save some much room. I would totally run that if it works!
Old 07-23-2014, 07:32 AM
Very nice work.
Old 07-23-2014, 08:57 PM
Ive got a lot of the parts to make it run.. But Im gonna need to teach myself some python coding.. Once I have something worth showing for real, i will start the build thread. Im hoping I can get some programming smart people to join in on the coding to make it go faster. Option 2 instead of running headless on iphone/ipad would be to put a small touch screen somewhere in the vehicle. The poster above with his switch panel made me think that a small 4" touch panel above the rear view mirror running XBMC would be pretty slick depending on how its integrated. And furthermore, i could integrate a rear view camera/front view recording camera into it as well.. But one step at a time.. Goal 1 is headless pi running rock lights and some auxiliary lighting
Quick Reply: Switches for extra lighting
