Switches for lights
Switches for lights
is anybody familiar with the rocker switch panel that is the 2016 Sahara? Can the blank slots be filled with matching rocker switches for lights and such?
If you're talking about this one it can be done. Not exactly straight forward though as there is a circuit board behind it. I have read about people getting a new switch assembly with every spot filled and using that to trigger lights. I have not seen a write up on it, however.
https://www.youtube.com/watch?v=9QrDxvd6uj4"]https://www.youtube.com/watch?v=9QrDxvd6uj4
With the circuit board behind the switch panel they will not fit. There are options for running aftermarket switches. Here's a few popular ones...
This mounts where the little net panel is behind the shifter. Guys with manual transmissions complain they accidently hit the switches sometimes though.
This mounts on the A pillar.
And this is an elegant way to add six or 8 switches but is much more expensive.
There are other switch mounting options if you search.
I have a cheap switchpod I got off ebay for my A-Pillar. It works really well, within arm reach for easy access, and (personally speaking) I really like how it looks. It fits perfectly and looks like it was meant to be there.
Not to take over the OP's thread but do you have a link to the one you got? Also how do you like it? Does it seem cheap? I've wanted to buy one of the less expensive ones since I can't afford the spod a t the moment.
http://www.ebay.com/itm/Left-Hand-A-...5X1K-w&vxp=mtr
