tire pressure light
How much have you driven it since the new tires went on? Certain parameters have to be met to get the light to go out.
Did you have the old sensors installed, or did you get new ones?
What pressure are you running, compared to what's listed on the B pillar sticker?
How old are the sensors?
Once you air up you may have to drive over 15mph for up to 20 minutes to be sure all readings are taken.
One problem you might run into is the battery life is supposed to be about 6-9 years.
