Turn signal issue
Turn signal issue
Had this just happen on my 2014 unlimited. Put key in ignition and left turn signal dash light as well as the front and rear turn signal lights come on with the turn signal selector in neutral position. Stayed on the entire way home and would only go off if you moved the switch up to activate the right turn signal. Be. As soon as you made a right turn and the lever moved back to neutral the left signal would come back on and not go out. Got home, turned the Jeep off, waited a while a cranked it again with no issue. Went back out later and tried it again and the issue had returned. Also when it does this I watched the front and rear turn signal lights. They would flash normal and about every 4 or five flashes then would flash kind of weak like it was shorting out. Any help would be appreciated!
