Underseat Sub Enclosures
Old 05-24-2015, 08:32 PM
ArcticJK808's Avatar
Default Underseat Sub Enclosures
Does anyone know where I could purchase subwoofer enclosures to go under my driver and passenger seat?
Old 05-25-2015, 04:29 AM
J1nx93's Avatar
User on here named Mattk11 made mine. I wanna say I saw recently that he's picking up more orders here soon.
Old 05-25-2015, 12:58 PM
Wrangler428's Avatar
Definitely Mattk11, he just did mine and I think he said he had a few more ready.
Old 05-26-2015, 04:09 AM
Mattk11's Avatar
I built a couple versions for my Jeep over the last couple years:
Made these with carpet and Sundown SD-2 10": Click image for larger version
These are Line-Xd and Sundown SD-3 10":
Both examples have internal volume of .6 cu ft. First has a mounting depth of 5", second has a mounting depth of 4 1/2" and is solid Fiberglas with 3/4" MDF mounting ring.
Old 05-26-2015, 06:32 AM
orangedude71's Avatar
Matt, I'd like to build one of these for my passenger side. Looking through your old posts I found this picture. Are the two things in the front your molds? You then made an upper and lower section then glassed them together? I assume the recessed ring is where you put the mdf ring during the mild over process.
Old 05-26-2015, 08:28 AM
Mattk11's Avatar
Attachment 612331
Yes they are molded to the floor pans in the Jeep and extend up into the seat frames. I've seen other people try to do these under seat subs, but their boxes weren't big enough so they were basically mid-bass pods, not true subwoofers or they just built them for 8" subs. It all has to do with the internal air volume. With these 10" Sundowns, I'm getting very low bass in the 23-25Hz range. Honestly I did them myself because my local custom shop wanted $350-450 per enclosure and couldn't figure out a way to get me .6 cu ft and I wanted 10s. In the grand scheme of things, I have dual 10" including the woofers for less money than a JL Stealthbox that ISN'T stealth and is only a single 10.
Choose your woofer and that will tell you how large the enclosure should be. Most 10" woofers need at least .5 cu ft and you have to make them closer to .6 cu ft to account for the mass of the woofer itself. Took me 4 prototypes to get to the optimal size.
Montego (11-09-2022)
Old 05-26-2015, 01:15 PM
DirtRider....'s Avatar
These are great looking... once installed... do the sub boxes interfere with rear passenger feet space? meaning, will adult feet be limited at all and/or will someone's foot ever come into contact with the sub itself? not sure if i'm asking this right or not... lol
also, how do you keep the tops of the woofers clean? just use your air hose once in awhile to blow the subs off from dust?
Old 05-26-2015, 08:14 PM
Mattk11's Avatar
No they don't interfere with the rear passenger unless they have huge feet. At least I've never had anyone in the back seat even ask about what is under the front seat.
I guess they can get dusty but but they are pretty protected up under the seats. Like you said, you can use an air compressor to blow them off if you think they need that.
Old 08-14-2016, 06:46 AM
Nkirk82's Avatar
Default I need these
Hey Mattk11 I'm interested in getting a set of these. How do I go about getting an order placed with you?
Old 08-14-2016, 07:51 AM
Mattk11's Avatar
If you have any question, please send me a PM.
I've made some improvements and all are Line-X'd now. I've found that it deadens the enclosure, looks great and makes it completely waterproof. (I know because my Jeep had 4" of standing water in it last Thursday)
ID:	654535 Click image for larger version
ID:	654536 Click image for larger version
I've also started a project for a rear mounted sub for a 2-door:
Quick Reply: Underseat Sub Enclosures
