Wiring an Off Road Trailer
#21
One question I have is related to grounding. The fuse block does not have a ground connection, so I assume the approach is simply run all grounds from the appliances, lights, etc to the switch and then from the switch to the same location on the trailer frame?
And, then the same from the negative terminal of the battery to the frame.
#22
One question I have is related to grounding. The fuse block does not have a ground connection, so I assume the approach is simply run all grounds from the appliances, lights, etc to the switch and then from the switch to the same location on the trailer frame? And, then the same from the negative terminal of the battery to the frame.
Then just be sure to have a good solid connection to the frame with a good thick gauge wire run back to the negative post on your battery.
This doesn't apply because your trailer has its own battery.
#23
Relay or no relay??
I'm all wired up now, but I had a friend criticize the setup due to me not using any relays. So, I pose the question:
Based on my wiring schematic previous posted at the beginning of the thread should I have used relays? Was this poor design? Am I in threat of overheating the lines and causing a fire?
#25
Relay or no relay?? I'm all wired up now, but I had a friend criticize the setup due to me not using any relays. So, I pose the question: Based on my wiring schematic previous posted at the beginning of the thread should I have used relays? Was this poor design? Am I in threat of overheating the lines and causing a fire?
#27
It's no problem! I've been exactly where you are and the folks on this forum have taught me more than I can even believe. Lots of people know lots of things way better than I do, but I was always very interested in wiring and electronics so I studied and learned as much as I could because I can use it so frequently. I can't wait to see some pics once everything is done!
