Wiring rigid lights for multiple options with spod
I currently have three scenarios where I want to use rigid led lights in different ways
i have an spod and love it
scenario a : I have a set of du ally's on the front bumper. I want them to come on when the high beams are on and I want to be able to switch them on without high beams on. I thought I could wire them to 2 spod switches , one that uses the high beam capability and the other just on or off. But I worry that I will accidentally turn both switches on and cause damage to the light?
scenario b: rock lights to come on when the door opens or when I push an spod switch. What happens if I do both, door open and the spod switch is on
scenario c: similar to rock lights but instead I have lights in the rear that should come on when in reverse or when I switch them on with an Spod.
I guess the question is if i run 2 12v lines to each light what will that do to the light and if it damages it how would you run the wires to prevent such an issue given the scenarios above
many thanks in advance
Not sure if this would be what your talking about....I wanted to run my duallys bumper mount and windshield mount using sPOD switches...but I also wanted a strobe...I used a flasher module activated by one of the switches on the sPOD...then used rectifier diodes to keep the voltage flowing one way...and wired all my lights into the strobe...the diodes prevent backfeeding... So I can turn the individual lights on using the corresponding switch...or I can strobe them all using my Zombie Apocalypse switch :-)....if the lights are already switched on...they will not strobe if the ZA switch is thrown...so if I'm driving down road with headlights on or hitting my brakes...they wouldn't start strobing or wig wagging if someone accidentally hit the switch...
Edit b/c my italics didn't show up in the quote. Even if both switches were turned on you're not going to damage the light, think of it like electricity isn't bing pushed, it's drawn by the device you're running. Also, you can accomplish a switched and auto-reverse light set up using relays or diodes to control directional flow of the electricity. 14Sport has a post somewhere describing exactly how to do it via electrical diagram.
Two wires feeding one light just reduces the amount of current that each wire carries. Won't harm the lights as JC said.
Just wire the aux backup lights using the sPod like you would normally do. Then add a jumper from the OEM reverse wire to the same pin in the sPod that the switch is wired to. The diode prevents the OEM reverse lights from coming on when you flick the aux switch. If you want OEM reverse lights to come on with the aux lights via the switch you can leave the diode out but everything needs to be rated to handle the additional load.
You could use this schematic for all 3 scenarios except tapping the high beam wire for "a" and the dome light wire for "b" instead of the reverse wire.
You could also do it using dual relays instead of soldering in a diode. You would only have to add one relay since the sPod already has the other in the circuit.
Ok... was going to try and accomplish this over the weekend, but got tied up. Question about attaching the wire to the relay in the sPOD, how do you get to it? I believe this is a circuit board, so would i need to tap into that or is there anther way to do it?
Maybe someone who has done it will chime in.
