Wiring rigid lights for multiple options with spod
Two wires feeding one light just reduces the amount of current that each wire carries. Won't harm the lights as JC said.
Just wire the aux backup lights using the sPod like you would normally do. Then add a jumper from the OEM reverse wire to the same pin in the sPod that the switch is wired to. The diode prevents the OEM reverse lights from coming on when you flick the aux switch. If you want OEM reverse lights to come on with the aux lights via the switch you can leave the diode out but everything needs to be rated to handle the additional load.
You could use this schematic for all 3 scenarios except tapping the high beam wire for "a" and the dome light wire for "b" instead of the reverse wire.
You could also do it using dual relays instead of soldering in a diode. You would only have to add one relay since the sPod already has the other in the circuit.
- The top ON position should turn on the backup/reverse LEDs regardless of the OEM reverse lights or transmission gear. Forced on if you will.
- The middle OFF position should turnoff the LED backup/reverse lights completely.
- The bottom ON position should allow the LED backup/reverse lights on come on with the OEM backup lights when I switch into reverse.
Does anyone have a wiring diagram on how to do that or know what model of DPDT switch I need?
Thanks in advance!!
The sPod already has the relay. You would just use that. You would have to remove the sPod switch and replace it with an on/off/on switch and then tap the reverse circuit to feed the new switch along with the wires that are already at the switch. I don't even know if they have Contura 3 way switches but if they do, you could use a SPDT one as well as long as it's 3 way, namely has an off position in the center.
I currently have three scenarios where I want to use rigid led lights in different ways
i have an spod and love it
scenario a : I have a set of du ally's on the front bumper. I want them to come on when the high beams are on and I want to be able to switch them on without high beams on. I thought I could wire them to 2 spod switches , one that uses the high beam capability and the other just on or off. But I worry that I will accidentally turn both switches on and cause damage to the light?
scenario b: rock lights to come on when the door opens or when I push an spod switch. What happens if I do both, door open and the spod switch is on
scenario c: similar to rock lights but instead I have lights in the rear that should come on when in reverse or when I switch them on with an Spod.
I guess the question is if i run 2 12v lines to each light what will that do to the light and if it damages it how would you run the wires to prevent such an issue given the scenarios above
many thanks in advance
Unless it has a center off position then one or the other will always be active. Meaning it will always come on with the reverse lights or always be on depending on the switch position. You will not be able to shut them off so they don't come on with the reverse lights. Is that what you want? If so, post the schematic for your current switch and I will tell you what wires need to go where. The switch schematic you posted above is not how you would do it unless you reversed the 1 and 2 wires and pin 1 is normally open. You basically want to use the pins in reverse meaning the incoming pin 2 becomes the output to the relay, the reverse light tap connects to the normally closed output pin (whether it's 1 or 3), and the current spod to relay wire connects to the normally open output pin (whether it's 1 or 3). Normally closed simply means this is the pin that is connected when the switch is off. Normally open is the pin that will be connected when the switch is on.
The second diagram is what I think I need to do to accomplish what I want.
1. Replace the stock sPOD switch with an ON-OFF-ON SPDT.
2. Run one wire from the OEM reverse lights circuit to the sPOD switches. (I don't think the diode is really needed but might be a safety net.)
2. Use the one input/common terminal as an output instead running it to the sPOD source box and relay. This is really already done by the stock sPOD wiring so I just need to move from input to output at the switch.
3. Use the two output/dedicated terminals as inputs instead with one from the sPOD and the other from the OEM reverse circuit.
Here are two diagrams, albeit very simplified, of what I was thinking based on what I've read and various input. I'm thinking to need to make sure this level is right before I think about the actual pins on the new switch. The first diagram is the standard sPOD setup with only the sPOD controlling the aux lights.
Attachment 640184 Attachment 640185
