Yellow Headlights
Yellow Headlights
2009 Jeep JK 4-door Headlight Question - I have tried multiple headlights to replace my stock ones - I've tried the canbus adapters with no results - the results I usually get are either one headlight is on and the other is off or no lights at all - luckily Amazon allows returns - the only upgrade I've been able to do to upgrade the stock lights is the Hella H4 conversion - they work great on bright but they appear "yellow" or like they are not getting enough voltage on dim - I've checked the voltage and it appears to be right on - does anyone out there have any suggestions? Thanks in advance
Just buy some good LED headlights and be done with it . Your just wasting your time and money buying other bulbs they all suck compared to LED And the voltage your getting is all your going to get it's a 12 volt system you might get a small improvement if you used an aftermarket wireing harness but it would hardly be noticeable.
As stated above, have bought several sets and types of lights including LEDs - all with the same result. Was at a swap meet on Saturday and came across a light vendor that was selling LEDs - claimed he owned a Jeep and knew all about the stock piss-poor lights - showed me what he recommended - bought them, go them home and installed, nothing lit up - back to square one. Thanks for the reply.
You are guessing that you understand what he never actually said. The devil is in the details.
There are reputable LED headlight assemblies, and then there are not. When your finished playing games to see how much compromise on quality and performance you can choose to live with.... go and get the reputable ones that have a company that stands behind the design and function of the lights. Then your done and not thinking about this any longer.
I thought I recalled someone saying that the canbus system allows around 8V (clipped square wave?) to the headlights when not on high beam?
"the results I usually get are either one headlight is on and the other is off or no lights at all ..."
Who made the CANBUS adapter you used? What you describe is two of the three symptoms (the other being the flickering that can occur) that PWM (Pulse Width Modulation) can produce.
Did you try a different adapter?
[QUOTE=jedg;4283484]"the results I usually get are either one headlight is on and the other is off or no lights at all ..."
Did you try a different adapter?[/QUOTe
I have tried complete headlight assemblies, one being Sunpie - put one in my '13 Streetglide and it was amazing - ordered two more and used a set of canbus adapters as they recommend- neither lows or highs would work - took one out and installed in Streetglide and it worked great - I do have another set of canbus adapters I'll try when I get home - thanks for the reply
I bought the jwspeaker headlights just plug them in and go takes 20 minutes and haven't had any problems with them. The reason is I played the cheap headlight game when I had my TJ and figured I had 3 to 4 hundred dollars in it without any real improvement so this time I went for it and have been very happy with them.
