mikeJKUR - 2014 black 4 door Rubicon build.
#21
Well he is the latest update. I was planning to add a winch so but superwinch had a 40% Labor day weekend so I picked up a Tigeshark 9500 with synthetic rope for $350.
I did weigh the winch and the bumper since I had it off.
This is what my bumper weigh minus the winch plate.
In my excitement and lack of of knowledge I did not take measurements to see if the winch would fit my bumper. Due to the fact the solenoid control box is mounted on the side and the shape I couldn't mount he winch since I have a recessed bumper.
#22
]Let me start by saying if the control box mounted in the middle or different shape I would have just mount the winch and been happy but now I am glad I had to move it. Very pleased with the results.
After talking to superwinch and looking at it myself the box does little to nothing to protect the solenoid environment so I planed on mounting the solenoid without the box. I believe where I have it mounted it is better protected from water, road slat, and mud then if it was still in the box on the winch.
I originally wanted to mounted it behind the grill but didn't want to take the time to make a mount after taking the bumper off 8 times this month for test fit ideas I decide mounting the solenoid to the battery box was the most straight forward way for me to do.
I removed the control box and solenoid from the winch and ran the wires following the factory harness along the right side of the engine bay. I did removed the air filter box to make it easier to run the wires up.
I then removed the battery and the 1 bolt the mounts the battery box the fender. I ran 2 wires in-between the battery box and the fender and the other 3 wires where the battery box meets the fuse box.
For the solenoid, I wanted it set as low as possible in the box. There is one harness that run along the left side of the box. I detached it from the box and drilled 2 new holes for the mounting clips at a lower spot. I drilled 2 more holes for the solenoid and bolted it directly to the box. As for the plug, there was already one hole on top of the box and I mounted it there.
Here is how it looks with the battery in.
#26
Oh I forgot to update this. I went to Red Cloud off road park a few weeks ago. Its great to have a park so close to home. I did get to use my new winch.
http://youtu.be/yrOJgq2TmqY At some point I put a dent in my oil pan on one of the trails. I keep saying that skids are the most important thing but keep putting it off. Time to pick a set and order.
#27
Great thread, love all the updates! How is the roof cart? I didn't know we could set the hardtop on rear glass like that? I think I'll have to look into something like that since my top takes up the whole garage!
#28
I just noticed you don't have a front license plate. Have any cops pulled you over for it? or do you normally run with one? I only ask because I had to zip tie mine to the stinger. There was nowhere else to put it.
#29
Its not bad. It dose not set on the glass. It sets on the area above the glass and the 2 lower corners of the roof. There is also strap that goes around the roof to help keep it in place. I use painters tap to hold the glass in when removing.
#30
Oh the tag is always on. On the bumper I have the bracket flips up when the winch is needed.
