Connecting Tow Straps Safely
How-Tos on this Topic Last edited by IB Advertising; 12-29-2015 at 11:33 AM.
See related guides and technical advice from our community experts:
Browse all: Jeep Wrangler JK Off-Roading Guides
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
  1. #1
    JK Super Freak goldtr8's Avatar
    Join Date
    Dec 2007
    Location
    MI
    Posts
    1,320
    Default Connecting Tow Straps Safely
    I was wheeling with a few guys this weekend in deep snow and we had to connect two tow straps together.
    One guy went into the back of his jeep and got a small wood dowl rod and made a special knot with the rod. He explained that you never want steel in the system if something breaks and also if you need to remove tension you can pull the wood out like a pin. it all made sense to me.
    Here is the question does anyone have a picture of how you make this safe knot. I would like to get the extra bits and pieces and put it in my off roading kid but if I cant make the knot it wont do any good.
    Thanks
    Mine 08 Rescue Green Rubicon, 6-Speed 1.75 inch Daystar Lift, Evap Canister Skid,Elec Brake Controler, BlackHawk CB, Smittybilt Winch, Mopar Front Bumper, HighRock Rear Bumper, Currie E-Z Deflator, Harbor Freight Air Pump, 8000lb hand winch, 48 inch farmer jack, IC-7000 All Band HF/VHF 100W Ham Rig
    Hers 09 Unlimited Deep Water Blue All Stock
    Daily Driver is a Turbo Dart
    I've been to MOAB it is now my favorite place on Earth
    visit the great lakes area
  2. #2
    JK Junkie racer83l's Avatar
    Join Date
    Sep 2007
    Location
    Long Island, NY
    Posts
    3,306
    in the past, ive looped them together... but it was a major PITA to get them apart. Id also like to know how this worked
    I dont Jeep
  3. #3
    JK Junkie scouter4life's Avatar
    Join Date
    Aug 2007
    Location
    Gilbert, AZ
    Posts
    2,944
    Not sure what knot would include a wood dowl that can be pulled, maybe a sailor on here could help out as I'm sure it would be something used in sailing. As for tying two straps together, your best knot would probably be the good old square knot or if the straps are different sizes the sheet bend or double sheet bend. not matter how much tension is on the straps, getting the knot out will be easy and they will hold tight, just remember though that connecting two straps creates a weak point at the connection and you'll actually loose some of the strength it had. I don't reccomend jerking the straps when used this way, but good steady pulls should be fine.
    '08 Sahara Unlmtd 4X4, Jeep Green, khaki, MyGIG Lock pic'd, Rear & front cameras, 6spd, 2.5" TF BB, Jeeperman Rear with carrier, 32" BFG KM's, WP Rack System, Ultimate Air CO2, all sorts of lights, Cobra 75 CB & Yaesu 2600M Ham, Smittybuilt XRC-10 Winch, Olympic sliders, 4x Fix-it front bumper, AEV Snorkel
  4. #4
    Eternal Moderator HappyCurmudgeon's Avatar
    Join Date
    Oct 2006
    Location
    Niagara, New York
    Posts
    18,276
    Not my picture, i found it on the web, but this is the basic idea.
    Like so:
    there is little force on the "towel" an old wooden handle or dowel works fine, I have one of those little aluminum cinchbone thing, but i have never used it. I have pulled a lot of heavy machinery on the farm using a simple 3/4" dowel.
    when your done pulling, releasing the tension on the straps will make thm just about fall apart, no knots to fight with (and lose)
    ~Ever Onward~
    CANCER SUCKS
    US Air Force veteran and damned proud of it!
    Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
  5. #5
    JK Junkie jkkat's Avatar
    Join Date
    Dec 2007
    Location
    Everett, WA
    Posts
    2,578
    I have used one of my many shackles.
    07 2 Dr JK Rubicon named RubyDoo in black
    TeraFlex 2.5" BB with 4Dr Ruby springs
    Warn front and rear bumpers
    Skid Row engine/trans skid plate
    rear box 30"x36" full of tools and stuff
    High lift 4' on rear roll bar
    8274 warn winch
    PIAA 5" lights on windshield mounts
    Cragar 345 steel wheels in silver
    Riddler diff covers
    35x1250x17 procomp Xterrains
    Yukon 5.13 gears
    Alloy USA front CroMolly shafts
    TeraFlex 2Lo kit
    www.northridge4x4.com
  6. #6
    JK Junkie dburgette's Avatar
    Join Date
    May 2008
    Location
    Fort Wayne, IN
    Posts
    3,540
    Quote Originally Posted by jkkat View Post
    x2...This is the best way in my opinion. Just have a few extras on hand and you never have to tie anything together.
  7. #7
    Join Date
    Oct 2006
    Location
    Niagara, New York
    Posts
    18,276
    i wouldnt tie anything together with a shackle, they turn into projectiles if they let go, just like i would never use a tow strap with a hook.
    ~Ever Onward~
    CANCER SUCKS
  8. #8
    JK Junkie Yamaha90's Avatar
    Join Date
    Dec 2007
    Location
    Amherst, Ohio
    Posts
    3,317
    it's hard to explain but i think i'll try. i don't exactly know what he's talking about but i have an idea of how the wood would be like a pin.
    on second thought i'll try to draw a picture for you guys, i think this would work.
    put each loop in the center of the rod, then grab some excess strap and wrap it around the other part of the rod. do this for both sides, and slide everything towards the center. this would seem to make the pressure distributed equally, not breaking the rod at such a short point, making it easily un-done by releasing the pressure and bringing out the rod.
    does that make sense??
    Mike
    F/R Rubicon Axles
    3.5 Rock Krawler X-Factor
    Bilstein 5100's
    37x12.50R17 Nitto Trails
    17x9 AE Beadlocks
    Poison Spyder Crusher Flares
    Poison Spyder Brawler Mid
    Poison Spyder Armor / Knockers
    JCR Crusader Deluxe Rear Bumper
    130w KC Slims & Rigid Fogs
    Build by JMGDesignsLLC.com
  9. #9
    JK Enthusiast ccwbrd's Avatar
    Join Date
    Sep 2007
    Location
    Myakka City, FL
    Posts
    135
    Quote Originally Posted by HappyCurmudgeon View Post
    Oh they do....don't ask how I know
    2008 Sahara, Jeep Green, 4x4, Auto, 4.10' Detroit Locker Rear, Trutrac Front, 18's, 275/70/18 Dunlop Maxx Trac M/T, Mopar winch bumper with fogs, Superwinch X9, ACOS Front, OME Light Duty Rear, Bilstein 5100
    NORTHRIDGE 4x4
  10. #10
    Join Date
    Jan 2008
    Location
    Schaumburg, IL
    Posts
    224
    In reality, how often do shakles break? I am aware of the fact they do fail at times and they will become a hazard as they fly toward you....
    BUT....how frequent of an occurance is this if you have 10,000lb rated shackles. Do you think a high percent of the failures are due to using incorrect equipment and shackles designed for use with an ATV?
    I have been lucky enough to never have one fail - but I have seen chain and other items fail and the mess they can cause....
    Todd Smiley
    o|||||||o - Only in a Jeep
    2007 Jeep Wrangler X
    OME Suspension (2.0Front; 2.25Rear)
    Pro Comp 17" Black Wheels
    BFG Mud Terrain 255x75x17
    JKS Quick Disconnects
    Brute Force Air Intake
    RR XHD Stubby Bumper with hoop
    RR XHD Rear Bumper
    IPF Headlights, IPF Driving Lights
    Black Grill inserts
    More to come.......
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
