First time off roading... badd smelll help!
#31
#32
Every time my radiator gets hot enough I smell the mud from the last trail run, I'm going to guess that's what OP was seeing as smoke was water and mud steaming off radiator, I think he posted this months back now though...
#33
#34
#35
EXCELLENT idea with the sprinkler!
Mud will destroy the components of your jeep almost as fast as a heavy right foot and lack of common sense. That doesn't mean that you need to fear it, just accept that getting your rig muddy means that you will have to find a way to get that mud off...and taking it off the bottom of your rig is more important than taking it off the sides and hood.
Start by using the pressure washer at your local car wash. Wash the mud that you can see. Then kneel down next to your rig, and wash the bottom of it as best you can with the pressure washer. This means the inside of the wheels, the axles, the coils, the springs, the bottom of the tub, the frame, the cross-members, the control arms, you name it.
Unless you have a lifted rig on some seriously big tires or are on a creeper underneath your Jeep, this still won't get all the crud off. Step 2 (for me at least) is driving home and putting a sprinkler underneath your Jeep. I like the type that waves a series of stream back and forth continuously. The mud softens up when wet, and the repeated sprays of water will wash away most of it. Move the sprinkler around to make sure that all the various sections of the undercarriage.
#36
I've also been using the sprinkler for years now. Works good. I use one of those fan ones that just goes back and forth. It has adjustable width. I move it from the front under the motor, to under drivers side, then under passenger side. Finally move it to the back. I end up with a pile of dirt when it's done. I let it run for 10 or 15 minutes each side
