How fast can you run with aired down tires?
I'm running a 12 JKU Rubicon with 285/75-17 KM2's (34in) on stock Moab wheels. I've got some long stretches of desert driving to do with mostly pretty good surface where 30-40mph is ok but with lots of intermittent rough stuff at a crawl. I'd like to air down to soften the ride a bit. If I go down to ~20 psi, will 30-40mph be hard on the tires? I would trial and error this to be safe but I don't want to overheat and ruin any tires.
Whether or not it's the "right" thing to do or how many others would disagree, I wheel about 10 miles away each weekend. I run 8psi in 37" mud grapplers which are load rated at E. I've never aired up before I left and run the speed limit home, the max of which is 65 mph. I've never had a problem. Take that for what you will.
