New Manual Driver: Am I Missing Something??
The auto jku is easy enough to get in to 4lo as well, its a matter of putting the transmission in neutral, then the differential to neutral, let off the brake, put the differential in 4lo, and then the transmission into drive and on your way you go. To reverse it you just have to slow to a crawl and go back into neutral, if you try without going slow enough it makes unhappy sounds.
Speaking of shifters, you still have the junk stock plastic things? I picked up a set of Drakes and looooooooooove them, black billet withe the shift positions engraved on the T case, theres an engraved one for the manual too. They have mud terrain style tires around them for grips...... Sweeeeeet.........
1) I know in hi range you can shift without a clutch if you mesh the gears but what about low range?
2) what is this 2nd gear low range start? Are you using the starter to turn the whole drive train?
So I tried starting in 4lo today in first and second gear. Just an word of advice... I forgot to disengage the emergency brake and it stalled out with a harsh grinding sound so I would suggest not having the brake on. Once I disengaged the E-brake, its starts right up and just rolls right along without any throttle, it's pretty cool!
Using the clutch in deep water, mud, or sand is a no-no. The advice above is spot-on.
FWIW, for normal driving (not crawling in water/mud/sand) you can drive a stick shift all day without the clutch. its just a matter of matching engine RPM to the road speed and gear. I drove an old Toyota for a couple weeks without a clutch because the clutch master cylinder was shot and I was broke. Had to shut of the engine to stop, then shift into first and lurch away with the starter. Once rolling the shifts were smooth as silk using just the gas pedal and the shifter. This was driving in the city!
I you watch the in-car cameras during NASCAR races, you never see the driver's left leg go for the clutch except to start, and I don't think those gearboxes even have synchros.
Shifting up is pretty easy. The gas pedal should be neutral (neither accelerating of decelerating). As you lift the gas pedal, slip the gear lever into the the next gear as the engine speed drops. On a synchromesh tranny the gears will pretty much drop right in. If they don't, blip the gas just a little in neutral and try again.
Shifting down is a bit trickier. With a neutral gas pedal, slide the gear lever toward the next gear down, blipping the gas just a tad as you move through neutral. If you hit the gas just right, the gears will slip right in. If you miss it, no harm done because a synchro box will refuse to go into gear. You just hafta blip the gas a little more or less while in neutral and try again.
Think of it like merging onto the freeway. You are a gear, the traffic is the other gear. If you match your speed to the traffic you can slip right in. If you miss matching your speed to the traffic you pull over and report the accident. (Unfortunately there are a buttload of drivers who don't understand this simple concept at all!)
I think it would be easier to describe how to have sex to the uninitiated but here goes. . .
