JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Recovery Strap vs Snatch Strap
Old 08-01-2012, 09:21 AM
gman72762's Avatar
Default Recovery Strap vs Snatch Strap
Not quite sure which is best for recovery purposes. What are the pro's and con's for each?
Old 08-01-2012, 09:26 AM
hazel1992's Avatar
Snatch strap is best for recovery.
Old 08-01-2012, 03:49 PM
Tycho's Avatar
My thinking is you use what best suits the situation. Snatch straps are great when needed for a mud recovery etc but if just a steady pull is all that is required and not a snatch then I prefer a no stretch strap. Thus if the worst should happen and something breaks under load there is less chance of creating a missile due to no energy stored in the strap. Kind of like steel cable versus synthetic winch line.
Old 08-31-2012, 08:25 AM
ChrisJ's Avatar
So if I'm reading this right, a snatch strap is dynamic (it stretches) whereas a recovery strap has no give to it (I guess sort of like a tie-down strap type material)?
Old 08-31-2012, 08:36 AM
knight1000's Avatar
Recovery Strap vs Snatch Strap.... I thought they were the same and a Tow strap was the one without any give? I was told my ARB recovery strap would stretch a bit adding more and more tension.
Old 08-31-2012, 05:54 PM
bobberdown's Avatar
Snatch Strap is the way to go...
Old 09-01-2012, 09:11 PM
Tycho's Avatar
Snatch straps are generally nylon and more expensive. Straight cheap recovery straps are generally polyester. Some manufacture do stuff up and mislabel straps. We had an incident here a couple of months ago which very nearly ended up with a bent chassis. Retailer was quick to sort it out. I'm thinking about having a shortish recovery strap made up but will stencil NO SNATCH on it multiple times.
Old 09-04-2012, 02:54 PM
13rubi's Avatar
+1 That is what I have always read.
Old 09-07-2012, 05:12 AM
Jersey_Devil's Avatar
Screw all this crap... I get straps and chains off a town company that tows 18 wheelers.... If these straps and chains will hold a fully loaded 18 wheelers then I know my lil jeep will be just fine! Lol
Old 11-29-2012, 06:25 AM
autenb's Avatar
I'm a fan of the ones that the Navy uses to tie down aircraft. :-)
Quick Reply: Recovery Strap vs Snatch Strap
