Snatch block and D-rings
#31
I was under the understanding that the more line out from the winch you would actually have reduced the pull capacity of the winch?
#32
Here is a link to a Zeon 10s
http://www.warn.com/truck/winches/ZEON_10-S.shtml
Sent from my ADR6425LVW using Tapatalk
#33
Fewer wraps mean a single turn of the winch pulls less line. That means more force. Too bad you're not correct, however, because by extension larger tires would give us more torque and better gas mileage! LOL.
#35
Ok makes sense. So to maximize your pull you should start with most of the line out.
#36
#37
Ok, this thread is the very reason I do not read the entire thread. There is another use of the snatch block, which may have been or not been mentioned. Off set pulling. If you can't get a direct line (single pull or use of snatch block), you can use it to pull from a different direction. Did this with two snatch blocks once. The guy was around a outcrop of rock and we couldn't risk getting to him. We got the rig close enough, unspooled, laid out the line, connected up with tree straps and had this "zig zag" of winch going. It's a pulley. Use it accordingly.
#38
you guys should really read up on snatch blocks, if you have/use them.
So the more rope that is out on your winch, the more pulling power (closer to its capacity of 9k, 10k, whatever) as long as you have a couple wraps around the drum.
using a snatch block at the anchor and running the line back to your bumper will create a double line pulley system doubling the pulling power to 18k, 20k, etc.
linky below or look at warn/arb whatever.
SCHOOL OF RECOVERY «
#39
Location: Independence and Lexington, KY (depends on the time of year)
p.s. I got the information about using a winch that has a capacity 3x the weight of the rig from the very informational "Vehicle Recovery Bible" found here. Pirate4x4.Com - Extreme Four Wheel Drive
p.p.s. Don't flame me because I don't have a winch. I understand physics, and I'm a Mechanical Engineering Major in my 3rd year, and this does hold water.
#40
Adding to this: the snatch block, when running a line from the winch, to the block, back to the jeep, will only undergo the same force that the winch is putting on it. The line would, at this point, be under half the load as it would have been if it were directly attached to the winching point, as is the winch. The link that was included with the controversial diagram is referring to the fact that, since you can pull twice as much when using a snatch block, the snatch block is under twice as much force as the winch or the line. So, one should keep the weight of their rig, the pulling capacity of the winch, and the load capacity of the line in mind when purchasing a snatch block. It is recommended to use a snatch block that is rated for 2x the working load of the winch, which is recommended to have a working load of 3x the weight of the rig (because when you're stuck, your rig puts the winch under much more force than the pound-mass measurement of your rig due to friction, and when in mud, suction). p.s. I got the information about using a winch that has a capacity 3x the weight of the rig from the very informational "Vehicle Recovery Bible" found here. Pirate4x4.Com - Extreme Four Wheel Drive p.p.s. Don't flame me because I don't have a winch. I understand physics, and I'm a Mechanical Engineering Major in my 3rd year, and this does hold water.
