So, I'm an idiot and got my new JK stuck yesterday. Lessons and questions.
This is what im concerded about. ive dont this b4
Gonna give that a try later this evening. I'll post a pic if I can get everything all cleaned up.
Also, last question: if I were to have an issue with the clutch after shifting in water, how quickly would I know? Is it something I'd see/feel right away or would it just cause wear much faster? If it's the latter then I'm not too worried, just more wondering. Thanks for all the patience guys.
Edit: And I'm back. Got super paranoid before bed so I went and checked the front/rear diff fluid. They were both a greenish color--is this normal? Keep in mind it was dark and I was using a flashlight but I'll probably take another look tomorrow anyways. Any other fluids I should check? Want to make sure I do everything I can here to prevent any problems down the road. Sorry for all the questions.
Your diff oil is probably okay, as looking at the picture of your stuck, you were not that deep. You would probably have got through it with mud tires. On the other hand, better tread can let you get even further into the trail and deeper in trouble.
Sometimes if one is out driving around and sees an interesting path off the road on public land, it is hard to resist not breaking the "don't wheel alone" rule. Your mind is thinking "where does that go?" along with "I am in a Jeep!". I have been guilty of doing that several times (and got lucky). Nowadays I am at least more cautious if there has been much rain.
Unless the clutch starts making noise or slipping, I would not worry about it. It appears to me you may not have been in deep enough to submerge the clutch.
Good to hear about the fluids though. I had another 20 minute drive to work today and haven't seen any issues with the clutch. I may check the diff oil again to see in the daylight, but who knows. Is a little bit of water in there a huge deal, if there is? I'm just not sure what color the fluid should be in the first place.
1 Post
winch winch winch. get one and you wont need new tires or a lift or a butt buddy to pull you out. keep having fun in your jeep, don't let one lil ooops moment make you a complete pansy. wheeling solo can be one of the best experiences there is
Well, it's always good to wheel with someone else, for fun and for issues were you can't get a wench onto something to pull you out, ya I know that's not always the case, but it can happen. And I agree wheeling alone is fun.
I always end up wheeling alone so that's the reason bumpers and a winch were my first upgrade. I avoid the mud because it gets in everything including the frame rails and you can never get it all out causing it to rust from the inside out. I get stuck a lot on the rocks though and my winch has gotten me out of trouble many times. Maybe if I wheeled with someone that could spot me on the rocks I wouldn't get hung up so much? You will get stuck again just be prepared. Your clutch will very likely be fine and as you probably know by now you can start in gear with the transfer case in L4 range to avoid using the clutch in mud. Have fun in that Jeep. It's the most fun vehicle you will ever own.
