So much going through my head! HELP LIFT MY JEEP!!!
#31
A leveling kit is just a little booster on top of the coil spring, in case you didn't know.
#33
#35
We can tell, lifting and running the factory tires only degrades the drivability and performance of the jeep and otherwise makes it look funny. You will get a better breaker angle for those steep climbs.
#36
I'll eventually get new shoes but the Jeep build is going to be a long process for me. I'm just going to have to do it all step by step.
#37
With the leveling kit in the link below, will I need any additional parts like sway bark links or anything or is everything in the link below all I need? Also, will I need an alignment after installing?
http://www.4wheelparts.com/Suspensio...t_pn=EXP66150K
#38
With the leveling kit in the link below, will I need any additional parts like sway bark links or anything or is everything in the link below all I need? Also, will I need an alignment after installing? http://www.4wheelparts.com/Suspensio...t_pn=EXP66150K
Yea I would do a alignment after.
