Steel cable winch line
Synthetic is stronger but when the synthetic line breaks it's much much safer. However when the mechanical device on the end of the synthetic line breaks it becomes far more dangerous than what a steel cable to produce. I work with synthetic winch cables everyday that are rated at roughly 40k lbs or more. When the rope breaks it's much safer, on the other hand we use steel cables to move around 31 ton shields that have never failed yet.
Well then they are just trying to suck even more money out of their customers. Aside from improper care and/or improper use, there is no reason someone should need to replace the rope every 12 months.
But hey, you can never be too careful when it comes to recovery equipment.
Well then they are just trying to suck even more money out of their customers. Aside from improper care and/or improper use, there is no reason someone should need to replace the rope every 12 months. But hey, you can never be too careful when it comes to recovery equipment.
When pulling (or even stretching out), synthetic ropes should be shielded from rubbing against hard soil, rock or wood, or they may by worn or even melted by heat accumulated from pressure & friction.
In fact, it's not a bad idea to protect steel cables too from such friction, and to avoid sharp angles.
Synthetic and steel are different in their "sensitivities".
In very low temperatures, a steel cable becomes more brittle. At very high temperatures, it's the other way around -- touching a hot exhaust pipe would melt a synthetic rope.
That's about the equivalent of Castrol telling you to change your oil every 3000 miles.
I could see it with really hard and frequent use, but if you use it just a few times a year, no way would I replace it that often. Warn will make out great with this, though. The mark-up on the replacement synthetic line is ridiculous. IF they were $100, or south, then I could see it not being too bad a deal.
I have had my winch for two years, maybe 3. I've used it to pull maybe 3 or 4 times. No way I'm replacing it yet. It still looks and feels new. I worry more about UV rays, the way I use mine. I soak it periodically with 303 protectant.
I like steel because it's is easy to maintain and takes a lot of abuse. I keep an Indian blanket in my jeep that serves multiple purposes including placing on my cable so it won't let the cable sling shot.
Former Member
Former Member
When any rigging fails of any type for any reason there isn't any time to duck away.
If you're going to use it someday maybe it shouldn't be permanently on the front bumper. Only takes a few minutes to run a safely stored steel or synthetic cable to a recovery anchor point and attach to the winch drum. Quicker than unspooling from drum to said anchor point.
Whatever...looks good on drum
I work at Newport News Shipbuilding in Va. Every aircraft carrier moored at our piers is held there with steel cable. Our rigging department uses steel pendants and wire rope for 99% of their rigging. I work in the test department and do quite a bit of load testing and everything I have seen has been wire rope.
I think the important thing to remember is, whichever type of line you plan on using you need to inspect it on a periodic basis and know its limitations.
