JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Too much articulation on a stock rubi?
Old 04-19-2014, 08:09 AM
socal14rubi's Avatar
Default Too much articulation on a stock rubi?
Easy question: I had a chance to drive up one of those ramps where you can fully articulate the front suspension. Any risk in doing this on a stock JK Rubicon? Anything likely to break?
Old 04-19-2014, 08:30 AM
Rob 12B1P's Avatar
Just dont flop it. Other than that you should be fine.
Old 04-19-2014, 08:53 AM
Maertz's Avatar
if you break something on an rti ramp i will applaud you.
Old 04-19-2014, 02:04 PM
gunbo75's Avatar
It is not a problem.
Old 04-19-2014, 02:28 PM
gunbo75's Avatar
Attachment 546920
Old 04-19-2014, 07:34 PM
D3ADLY's Avatar
Your stock Rubicon is made to go slam it against some rocks and make it through the Rubicon Trail. Driving it up a little ramp is as easy for it as you looking at your wall.
Old 04-20-2014, 06:21 AM
DannyMalkin's Avatar
If you use 4 low just remember to not turn on pavement. Drive to the ramp, then use 4 low and go slow.
Old 04-20-2014, 07:16 AM
jpn
jpn's Avatar
Make sure sway bar is switched off and go slow up the ramp....first time ramper.....
You done need to be in 4wd u less you want to use 4low just to creep up...
Old 04-20-2014, 07:25 AM
JLsJK's Avatar
This is funny, good metaphor!
Old 04-20-2014, 07:43 AM
Ezekiel97's Avatar
Only thing you're going to break is your wallet from opening it so much
Quick Reply: Too much articulation on a stock rubi?
