JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Winch Basics
Old 02-06-2016, 01:54 PM
  #51
adamisadam's Avatar
Originally Posted by nhk19
Agreed! Snatchblocks are great. Wouldn't wheel without one. Used it many times and without having it I probably would have road home as a passenger. That said.....do any of you carry more than one? Or run into a situation the way you rigged the pull you actually needed two? I just have one currently.
I carry one, but everyone i wheel with also carries one.
Old 02-06-2016, 02:06 PM
  #52
notnalc68's Avatar
Warn 19000 lb block, $22.25. Found it on another thread, here.
http://www.ebay.com/ulk/itm/271970422239
Old 02-06-2016, 02:48 PM
  #53
adamisadam's Avatar
Warn Industries Snatch Block 19000 lbs Part 61560 Model 745 3130 New | eBay
That link says $44. Where did you find it for $22.25?
Looks like we want this one:
https://www.warn.com/truck/accessories/snatch_blocks_.shtml
Old 02-06-2016, 03:11 PM
  #54
notnalc68's Avatar
Originally Posted by adamisadam
That link says $44. Where did you find it for $22.25? Looks like we want this one: https://www.warn.com/truck/accessori..._blocks_.shtml
I bought it for $22. It went up I guess. I was clicking on the item I bought. That's still a steal.
Old 02-06-2016, 03:29 PM
  #55
adamisadam's Avatar
I sent the seller a note as to why the part number is different. It looks like the same part as this one but different numbers:
88899 Warn Medium Duty 19K 19 000lbs Snatch Block | eBay
Old 02-06-2016, 03:53 PM
  #56
notnalc68's Avatar
I sent the seller a note as to why the part number is different. It looks like the same part as this one but different numbers: 88899 Warn Medium Duty 19K 19 000lbs Snatch Block | eBay
That's it
Old 02-06-2016, 03:55 PM
  #57
notnalc68's Avatar
Old 02-06-2016, 04:19 PM
  #58
nhk19's Avatar
Thanks! But, have you ever need two? I hate relying on other people having something I need.
Old 02-07-2016, 05:24 AM
  #59
adamisadam's Avatar
I have not personally needed two, but I just ordered a second. I can think of two times when 2 blocks could have been used. Once was when a jeep was stuck up to the frame in serious mud crossing a creek. It was a trail guide on a Jamboree (we needed to make a new trail due to condition changes). They tried using two winches at once, but in hindsight, they should have used snatch blocks to multiply winch capacity. Stupid, but no one thought of it.
The other time (or two) was to pull people sideways in very tight trails. But I was doing the rescuing.
I just ordered that other one. I figured for $44, I'll have a second. I've spent $44 on dumber things.
Old 02-07-2016, 05:39 AM
  #60
nhk19's Avatar
I have not personally needed two, but I just ordered a second. I can think of two times when 2 blocks could have been used. Once was when a jeep was stuck up to the frame in serious mud crossing a creek. It was a trail guide on a Jamboree (we needed to make a new trail due to condition changes). They tried using two winches at once, but in hindsight, they should have used snatch blocks to multiply winch capacity. Stupid, but no one thought of it. The other time (or two) was to pull people sideways in very tight trails. But I was doing the rescuing. I just ordered that other one. I figured for $44, I'll have a second. I've spent $44 on dumber things.
Thanks. Gonna do the same. I've have the high end ARB one now. Will get the $44.00 version too. Was thinking of several times it would have made the situation much easier.
Quick Reply: Winch Basics
