Winch Basics
#51
Agreed! Snatchblocks are great. Wouldn't wheel without one. Used it many times and without having it I probably would have road home as a passenger. That said.....do any of you carry more than one? Or run into a situation the way you rigged the pull you actually needed two? I just have one currently.
#52
Warn 19000 lb block, $22.25. Found it on another thread, here.
http://www.ebay.com/ulk/itm/271970422239
#53
Warn Industries Snatch Block 19000 lbs Part 61560 Model 745 3130 New | eBay
Looks like we want this one:
https://www.warn.com/truck/accessories/snatch_blocks_.shtml
#54
That link says $44. Where did you find it for $22.25? Looks like we want this one: https://www.warn.com/truck/accessori..._blocks_.shtml
#55
I sent the seller a note as to why the part number is different. It looks like the same part as this one but different numbers:
88899 Warn Medium Duty 19K 19 000lbs Snatch Block | eBay
#56
I sent the seller a note as to why the part number is different. It looks like the same part as this one but different numbers: 88899 Warn Medium Duty 19K 19 000lbs Snatch Block | eBay
#58
#59
The other time (or two) was to pull people sideways in very tight trails. But I was doing the rescuing.
I just ordered that other one. I figured for $44, I'll have a second. I've spent $44 on dumber things.
#60
I have not personally needed two, but I just ordered a second. I can think of two times when 2 blocks could have been used. Once was when a jeep was stuck up to the frame in serious mud crossing a creek. It was a trail guide on a Jamboree (we needed to make a new trail due to condition changes). They tried using two winches at once, but in hindsight, they should have used snatch blocks to multiply winch capacity. Stupid, but no one thought of it. The other time (or two) was to pull people sideways in very tight trails. But I was doing the rescuing. I just ordered that other one. I figured for $44, I'll have a second. I've spent $44 on dumber things.
