1 ton jk build
1 ton jk build
Page 1 of 19 12311 ... LastLast
Results 1 to 10 of 182
Thread: 1 ton jk build
  1. #1
    JK Enthusiast redx08's Avatar
    Join Date
    Dec 2007
    Location
    jackson,ms
    Posts
    383
    Default 1 ton jk build
    I sold my dana 44s off my jk last oct or nov, and sold my lift and tires not soon after that. I wanted to put one ton axles under my jeep, but didn't have the money to do what I wanted and buy axles from currie or dynatrac. So I called my friend that works at a junk yard and pulled some axles out of a 2002 F-350 and the build got started. The first thing I did was order a bunch of parts.
    Sterling 10.50 rear
    Dana 60 front
    Tires 39.5 13.50 17 Iroks going on 17 inch trailready bead locks
    Solid axle spyntec kit with my ORI that I am running in the rear.
    14 Inch travel RRD rock krawler coilovers with triple rate setup
    08 unlimited x
    Dana 60 front
    Sterling 10.50 rear
    Irok 39.5
    www.northridge4x4.com
  2. #2
    Join Date
    Dec 2007
    Location
    jackson,ms
    Posts
    383
    Tear down started
    rear axle removed
    Front end removed
    Clearanced the rear wheel well
    Rear axle truss
    Front frame rails cleaned up for coilover mounts
    08 unlimited x
    Dana 60 front
    Sterling 10.50 rear
    Irok 39.5
  3. #3
    JK Enthusiast tinobw's Avatar
    Join Date
    Nov 2010
    Location
    OC, CA
    Posts
    174
    Subscribed!
  4. #4
    JK Enthusiast remingtonJK's Avatar
    Join Date
    Nov 2009
    Location
    Cabot, AR
    Posts
    262
    Looks like your doing it up!
    Northridge
  5. #5
    Join Date
    Dec 2007
    Location
    jackson,ms
    Posts
    383
    Front frame mounts on with arms
    Had to remove the gas tank because the rear axle hit it
    Rear lower control arm mount
    Front lower control arm mount
    Transmission Cooler
    High steer arm and hub attached
    08 unlimited x
    Dana 60 front
    Sterling 10.50 rear
    Irok 39.5
  6. #6
    Join Date
    Dec 2007
    Location
    jackson,ms
    Posts
    383
    Moved some stuff around for the coilover mount
    Coilover mount, still to need to add some bracing and crossbar
    Rear ORI mount, these will be attached with a crossbar
    Ori mounted
    ON ALL 4
    Big thanks to yingyang. Still need to add tie rod, drag link, track bar, and mount the tj gas tank behind the rear axle. Should be rolling under its own power next week.
    08 unlimited x
    Dana 60 front
    Sterling 10.50 rear
    Irok 39.5
  7. #7
    JK Super Freak Serg5000's Avatar
    Join Date
    May 2010
    Location
    Palmdale,Ca
    Posts
    1,309
    Thats, how can i say this.....................SICK!!!!!!
    Serg
    2008 Unlimited X
    TeamRecon
  8. #8
    Join Date
    May 2010
    Location
    shilo MB
    Posts
    128
    ITS SO NICE
    cant wait to see the finished jeep and see it rolling !
  9. #9
    JK Super Freak jtjk's Avatar
    Join Date
    Mar 2010
    Location
    Santa Clara, CA
    Posts
    1,297
    sweet build
    2007 Rescue Green 6sp Rubicon -
    trek top
    flowmaster 44
    Aev snorkel
    rock hard stubby front bumper
    or fab tire carrier w Jerry cans & highlift jack
    Superchip Flashpaq
    cobra blue tooth cb
    Fire stick II Antenna
    xrc8 winch
    2xKC daylighters
    2xKC slim lights
    LED tantrum rock lights
    mickey Thompson classic ii matt blck
    37 toyo's
    gussets
    2.5 teraflex With Rock Krawler arms & Elka RR shocks
    Rough country 1.25 body lift
    Olympic Defender read bumper
    Arb Diff Cover
  10. #10
    JK Enthusiast doublebaggin17's Avatar
    Join Date
    Mar 2010
    Location
    Newark, DE
    Posts
    144
    WOW! What do you charge if I drop off my Heep?! Keep us updated
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
