2-door LS 5.3 swap!!!
With my setup (6.2L 6L80e) on 37" and 4:10 was great when lightweight (pre ace pro series rear bumper and carrier, smithy front + X-20 10.5k winch, rhino rails and D-60 rear, trusses and braces and teraflex monster everything) added enough weight to warrant 4:88 or 5:13 swap soon. She still gets up and howls rubber but in the soft sand and daily driving it would sure better the sweet spot for the trans/rpm program. 5:38 is getting into the weak (at least on a dana 44) spot on shafts with torque available so low.
Update the old BDS sway bar links didn't last long so I upgraded lol! LS swap has me hitting the corners harder than normal. Rock Krawler always have great experience with all my stuff (really is bullet proof lol).
New problem with the cam upgrade the brake are squishy, when on a hill it's difficult to stop. I'm thinking there isn't enough vacuum but I may be wrong any ideas on how to fix this? I'm now considering the teraflex master cylinder upgrade. So anyone with some advice would be great so I can get back on the trails!
I upgraded the entire system. Stock jk brakes were not up to the task. At stop lights the newfound power pushed through the brakes creeping forwRd.
I did the teraflex big brake kit , master , slotted rotors and crown lines front and rear. After several system bleeds it's nice and strong. Huge difference.
I upgraded the entire system. Stock jk brakes were not up to the task. At stop lights the newfound power pushed through the brakes creeping forwRd. I did the teraflex big brake kit , master , slotted rotors and crown lines front and rear. After several system bleeds it's nice and strong. Huge difference.
http://youtu.be/BRkuDWTR6R8
Here is a sound clip of it at idle
I deeply admire your skills!
I tear up daily as I hear it scream past everyone and the look on there faces is price less lol
Could not tell you as I have not ever used dyna kit yet. The Teraflex calipers are based off ram 2500 and caliper piston surface area/hydraulic fluid chamber requirements are a close match to what the teeny jk master can dish out.
