2-door LS 5.3 swap!!!
#21
Sponsoring Manufacturer
One of the advantages of our Pro Grip brake kit is you don't have to disconnect any of the brake lines, so there's no bleeding necessary. You don't have to change master cylinder or calipers, and will still see a significant increasing in stopping power. Here's a link that explains the Pro Grip in more detail:
A Better Jeep Wrangler JK Brake Upgrade from Dynatrac | Dynatrac Tech Info and News
The Pro Grip kit comes with new, larger diameter rotors, upgraded pads, and new mounting brackets for the calipers to help relocate them on the large rotors.
#22
One of the advantages of our Pro Grip brake kit is you don't have to disconnect any of the brake lines, so there's no bleeding necessary. You don't have to change master cylinder or calipers, and will still see a significant increasing in stopping power. Here's a link that explains the Pro Grip in more detail: A Better Jeep Wrangler JK Brake Upgrade from Dynatrac | Dynatrac Tech Info and News The Pro Grip kit comes with new, larger diameter rotors, upgraded pads, and new mounting brackets for the calipers to help relocate them on the large rotors.
#23
Will this work with the atx slabs? Also my issue is the brake feel really soft and I have to hold it all the way down to keep my jeep at a complete stop and even then sometime it inches forward after my built 5.3 swap. So do you think your kit would help eliminate this?
#25
#26
