ATX427 's JKUR Overland Build
#31
I'm looking hard at the getting a Front Runner Rack for my JK as well. I noticed that yours has been removed in your later pictures. Are you unhappy with it? What's your overall impression?
Btw - I've got XRC Armor on my four corners as well.
#32
Hey, I haven't been around here in a while. I do like the Front Runner rack system a lot, but I only use it on trips. I may be downsizing, so PM me if you are still in the market for one.
#33
#34
#36
Haven't checked in since doing my 3-link long arm
Pulled the front axle and did all new ball joints, steering arms and an Artec truss.
Fab'd up some control arms
6.5" up-tavel with 12" front shocks, 2.5" lift and 37's - Had to notch the frame to clear the lower CA's
Burned in the front upper mount.
Welded in the front shock mounts
#37
#38
#39
Went through a few iterations on the front. Started off with 1.5"x.250 wall DOM with a bent drag link for my Fox steering damper, the decided to eliminate the damper and go with a straight drag link, then upgraded to 7075 links and put the DOM on my 2007 Rubicon.
I have the original drag link for sale if anyone is interested. Just need to buy 1-ton TRE's
