ATX427 's JKUR Overland Build
Old 08-21-2014, 09:25 PM
  #31
Rubicon Beast's Avatar
Originally Posted by aTX427
After much debate, decided on a front runner full length roof rack.
I'm looking hard at the getting a Front Runner Rack for my JK as well. I noticed that yours has been removed in your later pictures. Are you unhappy with it? What's your overall impression?
Btw - I've got XRC Armor on my four corners as well.
Old 11-09-2014, 05:24 PM
  #32
aTX427's Avatar
Hey, I haven't been around here in a while. I do like the Front Runner rack system a lot, but I only use it on trips. I may be downsizing, so PM me if you are still in the market for one.
Old 11-09-2014, 05:30 PM
  #33
aTX427's Avatar
I made a few upgrades to the JK since the last time I visited this thread. Just installed a 2.5" OME HD lift with 37" MTR's and a Trektop NX. I also ordered a set of short body Bilstein 7100's and parts to build a custom 3-link front and rear. Stay tuned for the install.
Old 11-28-2014, 08:23 PM
  #34
aTX427's Avatar
Ditched the ARB bumper in lieu of an Expedition One DX. While I was there, I cut 3.5" off the frame and replaced the remote disco for an AR sway. I picked up about 4" of ground clearance and about 5" on the front.
Old 11-29-2014, 07:30 PM
  #35
semperfimrn1's Avatar
i love the rig! maybe ill see it around, if you have an spare parts shoot me a pm!
Old 10-02-2015, 06:08 PM
  #36
aTX427's Avatar
Haven't checked in since doing my 3-link long arm
Pulled the front axle and did all new ball joints, steering arms and an Artec truss.
Fab'd up some control arms
6.5" up-tavel with 12" front shocks, 2.5" lift and 37's - Had to notch the frame to clear the lower CA's
Burned in the front upper mount.
Welded in the front shock mounts
Old 10-02-2015, 06:20 PM
  #37
aTX427's Avatar
Cut everything off the rear and added a truss
Burned in the rear lower mounts
Upper rear axle mount
Lower rear axle mounts
Made my own rear track bar from a straight section of 1.5x.250 wall DOM
Bind free travel
Rear shock hoops
final stance
Old 10-02-2015, 06:26 PM
  #38
aTX427's Avatar
Bind free travel
Rear shock hoops
final stance
Old 10-02-2015, 06:27 PM
  #39
aTX427's Avatar
Went through a few iterations on the front. Started off with 1.5"x.250 wall DOM with a bent drag link for my Fox steering damper, the decided to eliminate the damper and go with a straight drag link, then upgraded to 7075 links and put the DOM on my 2007 Rubicon.
I have the original drag link for sale if anyone is interested. Just need to buy 1-ton TRE's
Old 01-21-2016, 04:10 AM
  #40
oletennessean's Avatar
is it possible to install the xrc fenders without removing the or-fab tire carrier? like just sorta loosen it and slide the xrc under it then re tighten?
Quick Reply: ATX427 's JKUR Overland Build
