CB Radio
CB Radio
Alright guys so have ordered a Cobra 75WXST! I also need to get the antenna and wires:( Would anyone give me suggestions to wiring it to the battery?
There's two cigarette lighter receptacles, one is hot all the time and the other turns off after the key is off. I tapped into the wiring for the one that turns off with the key (passenger side).
BTW: Some folks say to wire direct to the battery or you'll have problems. I've never had problems wired to this switched power, but others claim they have. So, just so you know in case you're one of the unfortunate ones.
Location: Independence and Lexington, KY (depends on the time of year)
I built myself a switch box for my auxiliary lighting and such with 5 switches, but 6 fuse slots in the fuse box. I used the extra fuse slot for the cb. Just ground to anything, but the battery is best.
