Fenderless JKs - Let's see em'
Old 05-10-2016, 05:38 AM
Shadow_Grey's Avatar
Originally Posted by jclaytor1
How did you do the rear frame where the frame stuck out behind the body? that looks awesome! upper clean!
Cut off frame at 45 degree angle even with the body along with all the other stuff and welded plate on to close it all up.
Name:	Rear frame cut.JPG
Old 05-10-2016, 06:06 AM
jclaytor1's Avatar
That looks so clean! good work. you cant have a trailer hitch anymore can you? since you cut off that rear cross member.
Old 05-10-2016, 08:34 AM
dr.dirty's Avatar
mine is kind of sort of fenderless. Trail mods flares. In the years I have had them only used the extensions once.
Old 05-17-2016, 06:39 PM
No have a truck and a car with a hitch for that...
Old 05-17-2016, 06:59 PM
ronin2120's Avatar
Here's my set up
Old 05-17-2016, 09:24 PM
highoctane's Avatar
Here's the back of mine. Just a rear fender delete.
Old 05-21-2016, 12:47 PM
dkazemba's Avatar
Anyone have any white fenders they took off?
Old 05-22-2016, 02:52 PM
Flex_Junkie's Avatar
Originally Posted by kcdee00
Attachment 646556 I took mine off and taped around the lip of the body where the fender came off and sprayed it with bedliner. I think it came out pretty good but I have since put my cut factory fenders back on. I have went back and forth with taking them off again.... Just not sure about it lol
Attachment 646557
Attachment 646558
You have anymore up close photos of this? Very intriguing idea.
Old 05-22-2016, 09:13 PM
renzo1200's Avatar
Jcr and Ace make some sweet fender deletes
Old 05-23-2016, 07:51 PM
kcdee00's Avatar
Here's a few more. Like I said, I have since put my cut down fenders back on... Which I can do with just a few clips. I think I am going to pull them back off tomorrow though. This is totally reversible. Only bad part is you have to cut the little support bracket off the front, which you would have to do anyways no matter what if you are going to run fenderless. My cut down factory fenders and inner front liners hang on fine without those brackets though so whatever.
Quick Reply: Fenderless JKs - Let's see em'
