flexing my short arm today
its more of a mid arm to me and depending on the limits of your control arm ends it will be very hard to have the mid arm be the limiting factor on most set ups, it will just suck under your jeep more.
Mid arm is just a fancy term because the jks stock arms are longer than all the other wranglers. Short arm or long arm. Not really such a thing as mid arms in my book
did you move the lower mount out more?
but either way looks good. throw up some shock specs im sure people will wonder.
yup that's about the max, are the shocks the bump or is there a small amount showing at full bump? I'm assuming you moved the lower mounts or they would be bending a decent amount at full flex unless the shock body is on the axle side.
