Homemade show off
#113
Some homemade... some modified....
These were modified from some rusting rampage rocker guards... the ends were wide and boxed in, so I used a torch to cut them off, then drilled the holes down the sides. Then I made reinforcement plates and grade 8 bolts to mount each side with the three underside stock mounts- and 6 pinch seam mounts... backed the pinch seams with plates on back side to give added strength. Then had them powder coated!
mud flaps... two wing nuts and they come right off, they hang on soem large eye bolts so the have some play in them. It is a ticket in Montana to have morethan 21 inches of tread not covered with a mud flap. So this is the "legal limit" LOL....
Oil pan skid... it has braces going up to the block, and it is glued to the oil pan.
This was a mopar bumper... cut 6 inches off each side, drilled it to match up to an AEV front skid, cut off the plastic bumps and the metal cans... it was an e-bay purchase because it had some surface rust.... it is one of a kind now!
I got the rampage bars for 200, the mopar bumper for 200, the aev for 100, the oil pan out of scrap and mud flaps from scrap... so 500 bucks worth of solid add ons... that is what I like about messing with used stuff.
#116
Built a tailgate table, not finished yet, will add molle packs to it.
Attachment 598141
Attachment 598142
Attachment 598141
Attachment 598142
#118
#120
I have made a battery box to power the cooler and other stuff while camping.
Attachment 598223Attachment 598224Attachment 598225Attachment 598226
