latches for tube doors???
Results 1 to 8 of 8
  1. #1
    JK Junkie robin's Avatar
    Join Date
    May 2007
    Location
    slp. Mexico
    Posts
    3,932
    Default latches for tube doors???
    does anybody know where to get latches for tube doors?? it would be great to find something like the ones RANCHO uses, I've been looking all over the place and I can't find them, any help would be apreciated !! thanks.
  2. #2
    JK Enthusiast Rubi up 07's Avatar
    Join Date
    Nov 2010
    Location
    Georgia
    Posts
    157
    You try calling Quadratec? They don't list everything online. Plus they can email you pics
    "Sometimes you just have to say WTF?"
  3. #3
    JK Freak Cunnart's Avatar
    Join Date
    Oct 2010
    Location
    UT
    Posts
    661
    could you buy replacement latches for a tj and older type jeep? Quadratec and 4wd warehouse sell replacement parts maybe that would work?
    www.jptrexevent.com
  4. #4
    JK Enthusiast yellow08jk's Avatar
    Join Date
    Mar 2009
    Location
    Chanute, Ks
    Posts
    224
    Default Bestop sells the same ones
    Google "bestop door latches" and you'll have several to choose from
    Kind of expensive though. I thought about them when I built my 1/2 doors but went a different route.
    Good luck,
    Jim
    2008 Detonator Yellow Unlimited - Auto, 3.73 - JKS ARCOS adjustable front spacers - 1.75" rear coil spacers - 35" Hankook RT03 - Rough Country quick discos - Mopar enhanced rock rails - Rugged Ridge XHD front bumper - Daniel Stern headlight setup
    Long Road to the love of my life
    1990 YJ-->1987 YJ--> 1991 YJ--> 1997 TJ--> 1985 CJ--> 2008 JK
  5. #5
    JK Junkie JK-Ford's Avatar
    Join Date
    Nov 2008
    Location
    Cabot, Ar.
    Posts
    3,297
    Have you thought about making a trip to your local junk yard?
    "The Green Monster" 2007 JK-X
    17" Fuel Lethal Wheels. Pro Comp AT tires
    Stock Suspension "For Now"
    6" KC 130w Long Range Lights on Smittybuilt Windshield Brackets
    6" KC 130w Driving Lights on "Grab Bar Mod" on front bumper
    Rock Light Mod
    Reverse Light Mod
    Interior Mood Light Mod
    [/CENTER]
  6. #6
    Join Date
    May 2007
    Location
    slp. Mexico
    Posts
    3,932
    thanks for the answers, I bought a set of latches from an old vw rabit and they work pretty good, they are similar to the ones used in hot rods, the advantage is that i can get them locally for less than 5 bucks each, and since I'm going to be selling the tube doors its a big advantage. thank you.
  7. #7
    Join Date
    May 2007
    Location
    slp. Mexico
    Posts
    3,932
    Quote Originally Posted by Cunnart View Post
    this would not work at all, we tend to think that rancho uses and old tj handle, but is not true the tj's latches and handles are huge and expensive.
  8. #8
    JK Newbie Toposurvey's Avatar
    Join Date
    Mar 2010
    Location
    Sacto, Ca.
    Posts
    11
    I found a small latch online. easy to mount. The only problem is they are intended for a much larger striker, but i just made a quick shim out of plastic tubing, it has to be replaced a few times a summer, but works fine and i didn't have to remove the existing stock striker. It's not pretty, but works. I'll take some pictures of the final product when i get the chance, (The doors have been through a few iterations sense these photos were taken).
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	136608   Click image for larger version.
ID:	136609   Click image for larger version.
ID:	136610   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
